G'day all,
I have recently had an ARB Linx system installed into my 2019 GXL and here are my initial impressions. I bought the system for a few reasons. Firstly I liked the ability to combine all of the accessory switches into one unit which is portable, Once my other accessories are installed i should be able to do things like turn my exterior lights on and off from anywhere around camp. The other reason is it replaces the need for an aux battery gauge and TPMS display (patch coming around Oct). I should also be able to load in HEMA maps and other 4wd apps.
Below are the negatives I learned about the system. Some are generalised to the Linx overall and others are Prado specific.
Prado-Linx interface
The Prado and linx don't talk well in regards to light pickup. This is a known issue about high beam pickup etc. For those who don't know the Linx system can be set to turn on and off accessories with both low and high-beam. In theory you can set your UHF (for example) to turn on when your low beams are on. With the canbus system the Linx will only recognise accessory power and high beam. There is no low-beam only option. So for most people, me included, this is not an issue as i cannot think of any accessory i would want to come on with low beams only. The issue comes with the Linx and the auto-darkening feature. The linx display will stay bright with the low beams on and only dim with the high beams. The app also has some software writing that overrides the displays own internal settings so playing with the displays settings is useless. I have had some luck with removing permissions for the app but if anyone else could share any tips?
Mounting:
The Linx in the Prado sits high. I suppose i could get used to it but and it is not in my vision at all (sits with A pillar behind it) but with the new VDU laws in the NT and QLD I am possibly playing with matches...
ARB was unable to find anywhere under my dash to fit the unit resulting in in being mounted on my drawers between the drawers and the 2nd row seats. Personally I like the location but in reality I will no longer be able to re-install my 3rd row without major re-wire of the system.
https://i.postimg.cc/mrWCnm1g/20190704-115438.jpg
Overall I am still in two minds about the system and only time, and a few more accessories will tell.
Mounting:
