I have a 150 series with a ARB Summit bar attached. Comes with two aerial mounts pretty central
LHS I have mounted UHF and now want to add another aerial for a Cel-Fi unit. Not keen to use the RHS bracket as that sits in front of driver. Prefer to mount further to the left of existing UHF aerial.
Problem is that the horizontal top bar on the Summit bar extending out to the left (and right) is not actually horizontal so a traditional clamping bracket will have the aerial leaning in. One solution would be to use the vertical bar out near the lights.
I have looked around and cannot locate a vertical bar clamp for the 60.5mm bar.
Hopefully all that makes sense.
Anyone seen a product that might work?
