GME UHF aerial cap when the aerial is removed
  • GME UHF aerial cap when the aerial is removed
    I have a GME UHF, with a AE4707B aerial , I tend to remove it when in the city, as people steal them, but if I remove the aerial, the connector bit it exposed, I have looked, but can someone suggest a screw in cap, that is the same thread as the aerial, but that covers the spring loaded base connector, so rain, etc doesn't get in.
    cheers, Simon
    GME make a rubber waterproofing cap to go over the spring base. Its part number is CA004 https://www.google.com/search?q=4707...client=gws-wiz
      The link to that GME accessory shows what appears to be a simple flexible cap. Are you after something more sophisticated? I have a detachable aerial on my boat. The part on the boat has a slip-on cap. To keep weather and moisture out of end of the aerial when it is removed, I simply purchased a round chair leg rubber from Clark Rubber (and couple of spares to go in the glove box.). Cheap and works.
      2019 Prado GXL 2.8L Diesel
      2022 Jimny too
        Only issue with that is finding a 41mm chair tip. A lot stop at 32mm.
          I think what Piggy mentioned should be fine, I had in my mind that there was something that would screw in. I'll buy two cap things, in case I lose one.
          Thanks guys.
            To close out this post, this is what I ended up purchasing, a N male dust cap for a S0239 connector, cost $6 or so, from my local electrical shop. Just screws over the aerial connector when the aerial is off, and keeps dust and water out.
              I fitted a dummy load connector when I removed the antenna. That way if transmit button is pressed without antenna fitted then no damage to output ccts on transceiver. Also stops water or dust.
Name:	Screenshot 2022-10-12 174146.png
              Online Shopping at a cheapest price for Automotive, Phones & Accessories, Computers & Electronics, Fashion, Beauty & Health, Home & Garden, Toys & Sports, Weddings & Events and more; just about anything else Enjoy ✓Free Shipping Worldwide! ✓Limited Time Sale ✓Easy Return.
