Which Phones do you have that work with blue tooth?
  • #76
    Originally posted by talk2tiny View Post
    I accidentally came across this when I was pairing an ipad just for sound and a phone. If you're getting the from car or from phone messages, you're in the 'BTA setup' menu, not the 'Phone Setup' menu. If you select your phone from the 'Phone Setup' menu, you should have no problems and it won't ask about the from car or from phone bit.
    Tiny,
    Thank you so much for that.
    I figured out what I was doing wrong- I didn't realise I had to press the steering wheel controls to initiate pairing, I was pairing only from pressing the stereo aux/USB button. (If any of that made sense)
    So for anyone else that might get into this predicament;
    I deleted the phone from the system
    Then pressed the hang up button on steering wheel
    Pressed in tune knob to initiate pairing
    Named the device
    Used tune knob (rotate) to select 'phone int' *default setting is 'phone'
    Pressed in tune knob to select 'phone int' setting
    VIOLA ! Bluetooth music and phone services.
    Thanks again guys
    • #77
      Originally posted by MrFurious View Post
      Tiny,
      Thank you so much for that. . .
      No probs. It makes an interesting change actually giving information out rather than asking for it. Probably not going to be a regular occurrence for me for a while.
      • #78
        Originally posted by reggie426 View Post
        We run our iPhone 4S and 5 with bt perfectly but use the USB port at the same time for music, keeps them charged up and can use the steering controls and random function on the radio screen.
        Can you confirm if the GXL Prado will enable an iPhone 5 to connect, charge & have audio being controlled through USB?
        • #79
          My iPhone 5 is brilliant in the 150.
          [CENTER][B][U]Matt
          [/CENTER]
          [SIZE=2]
          [/SIZE][CENTER][SIZE=2]
          [/SIZE][/CENTER]
          • #80
            Just been out fiddling with my iPhone 5 in the Prado and you're right, it's a ripper.
            • #81
              I find it annoying that if I pair my iPhone 4S with 'int audio' the Bluetooth works but its ALL AUDIO from the phone, ie email, SMS notifications try to go to the prados radio, but don't play because presumably the soud is too short. Music plays via BT well. I would love if only music and the telephone went through the BT audio.
              • #82
                I have my Blackberry and the wife's iPhone 4s connected to our GXL and the Blackberry connected to the work GX. Bit of a pain to swap between phones but otherwise never had any dramas
                Kev,
                • #83
                  Does anyone have a Galaxy S3 connected to their GXL?
                  Cheers Steve
                  • #84
                    Cheers Steve,
                    I went into the local dealers and they let me pair my phone and make sure the baby seat fits.
                    I couldn't work out the media streaming then and there but once I get my car I'll have a play and try sort it. Might even read the owners manual. 8)
                    • #85
                      Cheers Steve
                      Yep. Phone and audio streaming work fine.
                      • #86
                        Anyone running a Samsung S4 4G yet in a 150.
                        [b]Rob[/b]
                        • #87
                          Yeah I have one, no problem, in fact connects more reliably than my previous S2
                          [/SIZE]
                          • #88
                            Connected Samsung S2 rooted and HTC Velocity 4G no issues. Though, I use HTC a lot more than S2.
                            2013 ZR in Crystal Pearl With Bits From ARB Catalogue.
                            • #89
                              I have a Samsung C5220 that won't pair with my 2010 Prado GXL. It sees the car and asks for the pin but fails connection. Anyone had a similar experience with one of these phones?
                              Geoff
                              • #90
                                I have a 2014 GXL and an iPhone 5c. I have paired the iphone to the GXL Bluetooth. I can make and receive phone calls fine. My contacts have synced as well. But I can not get messages to setup and nor can I get any sounds when I receive emails or other notifications. Anyone have any tips please?
                                2014 Prado GXL, Silver, ARB bullbar, Old Man Emu, Safari snorkel, Rhino heavy duty bars, Electronic anti-rust, uhf, dual battery, dcdc charger, anderson plug, 3 x 3rd row cig plugs
