Tailgate Dropped
  • Tailgate Dropped
    G'Day all, I was wondering if anybody has come across the problem that is currently driving me nuts!! It appears as thought he rear door (tailgate) has dropped for some reason and is squeaking it's head off. I know have to drive with the radio cranking just to avoid hearing the squeak! Had it to Toyota this morning and the tech had no real idea and has suggested that the door may need to be replaced / inspected for cracking around the mounting points etc.
    In the meantime I have sprayed the latch and guide with Tac2 and this is helping by lubricating the rubbers.
    Has anybody else had any issues with this? I drive 220km a day and this is driving me crazy......
    HAD 08 D4D Auto with a few goodies - HAD 150 D4D Manual with a lot of goodies - CURRENT Vehicle 2006 1KZ Manual - about to fit full 3" Exhaust - Steinbauer Chip - Rhino Pioneer Platform - Ctek DC-DC & Optima dual battery - Baintech distribution Panel - Anderson plug to rear - Uni Filter - Snorkel - In dash GPS, reverse Camera, DVD etc - DVD in headrests for the kids..... and the remainder of wishes will have to wait!
    Hi NewyD4D,
    I had the same problem. Took the Workshop Foreman for a ride, he agreed there was an issue. Left it with them for the day. When I picked it up he said that the door was full of dust which they cleaned out - squeeking gone! However I have noticed that the squeeking is coming back after about 3,000km - and I haven't been on any gravel roads in the meantime...... So back to Toyota when it gets a little worse to make sure they acknowledge the problem.
    Steve...
    [b]Steve..[/b]
    White 150, GXL D4D Auto
    Bridgestone D694's, Toyota Tow Bar, 3M Tint, MaxTrax, ARB Bull Bar, GME 3340, Lightforce 170's, OME Lift, Dual Batteries
      Out of curiosity does your rear door "guide" show any wearing on the top part that is bolted to the body of the car?
        I think there was a similar issue with some 120 if you wish to search for it,
        something to do with the glue they use to put the door together failing
        causing the door to sag requiring replacement of the door from memory.
        LeighW
          LeighW
          I think this maybe the thread you are talking about Rear-door-crack
            My guide is heavily worn also, Toyota have looked at it and have decided to replace the gas strut that locks the door in the open position as they believe this is the cause of the rattles. It is on order, I am not overly convinced but will wait and see how it goes. Have found that the odd spray of Tac2 (Adhesive Lubricant) has stopped the squeak. In regards to the 120 issue (cracking of the seam around the rear door hinge area) this is so far not an issue for me.
            Hopefully the part comes in soon as I am off to Fraser Island in just under 4 weeks, so would like it to be fixed before that road trip.
              My rear door lock strut has failed in less than 10,000 km. Warranty repairs scheduled on Aug 10th..
              [CENTER][B][U]Matt
              [/CENTER]
              [SIZE=2]
              [/SIZE][CENTER][SIZE=2]
              [/SIZE][/CENTER]
                The 120's were only cracking on the first of them. When they bought out the 5 speed auto is when they modified the rear door......Cheers Steve
                  A way to check this for yourself rather than days of faultfinding is to remove it and do your daily commute. If the rattle is still there it will narrow down the search for the noise anyway.
                  [b]2013 GXL LC200 TTV8[/b]
                  TJM Alloy Bullbar
                  Towing a Jayco Expanda 17.56-2OB
                    TJM Alloy Bullbar
                      I had a knock from mine, I adjusted the door and striker etc
                      I had squeaks, dry seals cause squeaks in many cars
                      Spray silcone spray round all the seals.
                      Not sure if that's your squeak, but cheap easy fix, to try....
