Not 100% but have a feeling that you won't find a rated recovery point anywhere as there is no standard to manufacture to, most will likely have a working load limit (WLL) but this is only for a static load (lifting or pulling) not a dynamic load which you would have doing a snatch recovery.
That said as long as you buy from a reputable manufacturer who uses quality steel, quality trades people and quality processes to an engineered design, you shouldn't go wrong.
Can you use the factory tie down points, probably for a winch, maybe not for a snatch though.
While winching you can monitor the loads and back off or dig to relieve some of the load, when snatching this is not possible.
If you don't have bolt on points, you may not get help if you need a snatch recovery.
As with everything, you assume the risk whichever way you decide.
