Aftermarket front recovery points for 150 Series
    Michael did you mean to say that the captive nut plate should have been cut in half rather than the bullbar mount plate itself? If the bullbar mounting plate was cut in half it wouldn't work, just saying.
    Sorry if that was confusing, the captive nut plate needs to be cut in half. Use a plate or nut for the recovery point that suits the thread on the grade 12.9 bolt and the remainder of the captive nut for the bullbar mount. I am not usre what is supplied with the recovery points so if there is no nut or plate for that then TJM will have to grab one.
    Michael
    • Originally posted by gxllouie View Post
      mate i had a closer look at your photo...
      it seems that in order to fit the recovery point, they have omitted a bolt to hold the bullbar bracket onto the chassis. you can see the hole just above the recovery hook in your side on photo.
      have you checked with them if this compromises the bar?
      the roadsafe recovery points have another set of mounting holes so all bolts can remain in place.
      louie
      Hi Louie,
      You make a good point.
      I will raise this today with the shop where i got it done and let you know the outcome.
      150 VX diesel. Awesome bonnet protector! Monster Rides 3" Susp Lift, 265/70/17 MT MTZ's on Dick Cepek Torques, TJM T13 bar,TG150 Guard, Airtec Snorkel, Lightforce HID's, GME TX3540, CKMTA12 compressor, redarc dual bats, Drawers, fridgy drop slide, Maxtrax, More to come... one day!
      • Louie, looks like you were right.
        as per below email from TJM. i included a photo of my install and a pic of mjrandoms.
        Hi *****,
        Just had a query i would like to run past you with the recovery points that i had installed on Monday.
        You can see from the attached picture that due to the way the recovery point lies, it restricts the use of the second bolt to hold the bullbar bracket on.
        There are other recovery points that do not do this as the second picture shows
        I would just like you to confirm that this will not compromise the safety/integrity of the bull bar with the missing bolt?
        Also Considering the forces that these points could potentially be subject to, i am thinking would a higher tensile bolt be more appropriate, 10.9 or 12.9 rather than 8.8? I know that the "Roadsafe" brand of points all come with grade 12.9 bolts.
        Could you please respond with your thoughts on these few queries.
        Thankyou
        Adrian
        Hi Adrian,
        I was unaware that any bolt had been left out of the fitting of the bullbar to allow the fitting of these recovery points. I am of the opinion that the bar should have been fitted with all bolts as per the instructions, and that these recovery points should have not been fitted to the vehicle. We initially had organised a set of "Adventure Products" recovery points to be fitted, however they would not work due to the bracing on the TJM bar. The "outback ideas" recovery points (fitted) were then selected as an alternative. I am disappointed that I was not notified that a bolt would need to be left out to fit these, and I would suggest coming in to have these removed, and we would refund your purchase in full. At this stage I do not have an alternative, but I will do some homework as to what will fit with our bar.
        In regards to the bolt strength, both the Adventure Products, and Outback Ideas recovery points are supplied with 8.8 bolts. My assumption is that these companies have tested that this is sufficient, however I will look into this as a stronger bolt certainly couldn't hurt.
        Kind Regards
        after talking on the phone with him also, i found out that the adventure products ones only fit the GX/GXL which nobody knew before. and the VX and Kaka i'm assuming mount differently. Which is why they went the outback accessories points instead.
        I'm not super happy, because if it wasn't for Louie I would have been none the wiser. But at least the dealer is being easy to work with and coming to the party to fix it up.
        I'll be keen to see how you go with yours on friday Fido.
        • Just looking back through this the bullbar mount for Brains' T13 and my T3 are a bit different. Mine is S shaped and goes back down to the centre of the chassis where a bolt runs while Brains' seems to stop at the first bolt which allows the top recovery point bolt to be fitted and the rear hole is unoccupied.
          What does the VX/Kakadu look like?
          Brains:
          Mine:
          • mine seem to look very similar to yours mj
            unless the spacing is slightly different i don't see why the ones you've got wouldn't fit mine...
            • Definately looks the same. Where are the KDSS naughty bits that get in the way?
              • I think it's the hydraulic ram holding the swaybar in the picture that moves up and down.
                  The same as yours MJ. I can't recall if it was in this thread or the other Recovery Points one but I did mention there were bracket differences. As I understand it there used to be KDSS and non-KDSS versions of the bullbar mounting brackets, AFAIK they now use the same style of bracket for both.
                  Also as per the TJM T13/T15 installation instructions in relation to the mounting bracket on the driver's side :-
                  KDSS suspension models will only allow access to the rearmost hole in the chassis support bracket, which is sufficient fastening.
                  That is why you will find 2 bolts at the top of the bracket on the passenger side but only 1 on the driver's. Mine is like that and I don't yet have recovery points fitted, that's how it was installed.
                  So will I Ages, not exactly pleased about being a guinea pig for Roadsafe at my expense though. They did say if it wasn't going to work they won't muck around so hopefully they won't charge me if they can't install them. I do hope they can make it work though, otherwise I have 2 rather large paper weights.
                  • That makes sense.
                      Brains:
                      Mine:
                      And to confuse matters even more I have a T13 bar yet my Bullbar bracket is as per your T3 not Brains T13.
                      [SIZE=1][B][COLOR=#ff0000]2010 Silver GXL Prado T/D Auto.
                      [/COLOR][COLOR=#0000ff]2014 Leisure Matters X-Track Camper Trailer.[/COLOR][/B][/SIZE]
                      • So I've read through and and had a look at what people with the TJM have attached photos of and something interests me.
                        Ages. VX Diesel T13 Bar Bullbar bracket is the "S" type that uses both the threaded holes on the chassis.
                        fabes. GXL Diesel T13 Bar Bullbar bracket is the "S" type that uses both the threaded holes on the chassis.
                        mjrandom. ?????? T3 Bar Bullbar bracket is the "S" type that uses both the threaded holes on the chassis.
                        brains. GXL Diesel T13 bar yet seems to be the only one that has his Bullbar bracket different to all of ours (remember we are talking about TJM only not ARB) so I'm starting to think I wonder if during the installation process of Brains having his Bullbar fitted TJM have modified his Bullbar bracket to allow the use of the two rear holes of the recovery point......
                        I do like the fact the there are a total of 3 bolts that are mounting the recovery point on each side of the vehicle and if only 1 rear bolt is required to mount the Bullbar then perhaps this is the way to go.
                        Does anyone else who has a TJM Bullbar have the mounting bracket that looks like Brains?
                        • Mines a D4D auto.
                          • Originally posted by Ages View Post
                            Well I'm afraid it's not good news guys, the RoadSafe points will not fit correctly on my Kakadu with the T13 bar. I took it out to TJM this morning and they did a test fit but came up with these issues :-
                            1. On the driver's side there would be a 3mm gap between the point and the chassis caused by the end of the point overlapping the existing nut and washer on the outermost edge at the top of the bull bar mounting bracket and there is actually no hole in the chassis where the top bolt needs to go (that's the 2nd hole in from the outermost hole at the top of the point).
                            2. On the passenger side the point would fit but only if the top bolt on the bullbar mounting bracket had its washer removed. With the washer in place the end of the point would be sitting on top of the washer and the point would not be flush with the bar (just like on the other side). I asked whether the point could be packed out with a washer in between the point and the bullbar mounting bracket but they said that would compromise the strength of the point and they weren't happy to do that.
                            The guys at TJM said the points basically need to be redesigned so they follow the contour of the bullbar mounting bracket and both top mounting bolts with no overlaps. For the passenger side notching the end of the point so it goes around the outermost bolt on the bullbar bracket would solve the issue but that doesn't solve the issues on the driver's side.
                            So all in all a disappointing result for a product marketed as fitting the 150 series with a TJM steel bar. I will be following up with Roadsafe as I'm now left with expensive paperweights I can't use. My local TJM will also be following up with them as they say they have had similar issues with previous installs on other 150s. To TJM's credit they did not charge me for the time they spent trying to install the points even though I didn't buy them there.
                            • I am really confused. Is the Kakadu different to the VX? Ages recovery points look just the same as mine without the spare hole. Do you have pics?
                                Fido Sorry to here about your hassle. time to trade in on something more easier to modify 40series!?!?!?!
                                SOL.
