I went to my dealer today who initially suggested that he had no idea what I was talking about. When I mentioned that, having read this thread, it seemed Toyota has recognised the problem he quite quickly said that he's not sure that he has any new longer mud guards in stock but would find out and call me back. He finished by saying that the replacement would be done at the service centre at the expense of Toyota as it is an "identified problem". Quite clearly they are trying not to advertise their responsibility!
Mudflap Problem Solved ?
Originally posted by Pilbara prowler View PostI went to my dealer today who initially suggested that he had no idea what I was talking about. When I mentioned that, having read this thread, it seemed Toyota has recognised the problem he quite quickly said that he's not sure that he has any new longer mud guards in stock but would find out and call me back. He finished by saying that the replacement would be done at the service centre at the expense of Toyota as it is an "identified problem". Quite clearly they are trying not to advertise their responsibility!2010 150 Glacier White GXL D4D Auto
Originally posted by KAKADAZ View PostI have now installed my SR5 mudflaps over the originals....looks and works well although may get some longer factory ones once there in stock but in the meantime these will protect my new bumper thats about to be replaced by insurance.
Sorry about the crap quality phone photos...
Dont get me wrong, not knocking it, seeing as there is no other replacement available at this timeMy Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.
Guys,
Sorry if this question has been asked before. Will Toyota replace the mudflaps with the new design even if you don't have any stonechips etc on the body ? If so what is the process ?
cheersRob
Silver 2010 Prado 150 TD Manual, BFG AT 256/65's, ARB Deluxe bar, Tradesman Roof Rack, Warn XP9500 winch.
cheers
When I asked for mine I was told NO, as my vehicle was not damaged.
My reply "that can be arranged & the repairs to the damage will also be done at Toyota's expense".
Mine are on order Ex Japan.
Tar Trek.
Originally posted by Ryzz View PostThe only problem with the Hilux flaps, compared to the now unavailable Gravel Rush flaps, is they are not flexabile, so whilst they are great on the road, if you get any major flex in the back end, you will tear them off. I lost one of the gravel rush flaps and replaced it with a Hilux flap as a temporary work around, and tore it off on a 4wd trip when the back corner flexed to the ground.
Dont get me wrong, not knocking it, seeing as there is no other replacement available at this time2010 Kakadu with all the usual stuff.... Build up thread below
Originally posted by KAKADAZ View PostMine are very soft and rubbery much softer than the genuine mud flap...mine were cheap ebay (genuine apparently direct from Thailand) and cost $134 for four.My Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.
Originally posted by Ryzz View PostInteresting mine are almost solid with almost no flex, probably harder then stock flaps.2010 Kakadu with all the usual stuff.... Build up thread below
Originally posted by Riv39 View PostKakadaz, wow really shows the inadequacies of the original design!2010 Kakadu with all the usual stuff.... Build up thread below
cheers
Word of advice, make sure they check the box before ringing you to book the car in!Last edited by Riv39; 13-10-2011, 11:38 AM.2010 150 Glacier White GXL D4D Auto
we had the mudflaps replaced by a dealer in perth recently , as have been waiting for them to come in for a couple of months , the wife took it to get done and when she got home i can not really tell the difference , the front looks longer , but the rear , not sure , has any one got a picture or measurements of the new flaps installed , mine hang down from the car rear 80mm and the front 100mm , if i am near a toyota dealer today i will call in to see a 2011 150 if they have them installed
cheersTOYOTA PRADO 150 SERIES GXL D4D GRAPHITE
I had my mudflaps replaced a few weeks ago before a trip away. Now water drips along the rear mudflap whenever the rear aircon is running, they must have moved/left off a drainage pipe.
Nearly had a heart attack when I first saw it as we were a long way from anywhere and I thought it might be a fuel leak.[B]Steve[/B]
mine hang down from the car rear 80mm and the front 100mm2011 150 GXL D4D Auto White, ARB Deluxe Bar, Windcheatah roof rack, Warn 9000 winch, IPF Spotties, Mounted ARB Compressor, GME TX3540, Codan 9323 with 9350 Auto Tune Antenna, Kaymar rear spacer & HF mount, OME Sport Shocks & Springs, Safari Snorkel, 5T Rated recovery points, Exhaust Jack, BFG AT tyres, Maxtrax, Scangauge.
[/CENTER]
I thought 80mm rear sounded short. You would have thought whoever changed them may have noticed the new ones were the same length as the ones coming off.2010 Kakadu with all the usual stuff.... Build up thread below
