Squeaking brakes 2012 150
  • Squeaking brakes 2012 150
    Over the past few months I am getting low speed brake squeak from front brake LHS. Toyota's response was to "deglaze" the brake pads. Within a month I am back to squeaky brakes again. After applying the brakes a few times, the squeaking goes away until next time the car is driven ... presumably because the brakes cool down. I am concerned that either something is loose or metal is rubbing on the discs (less likely). Nothing has happened to the vehicle to cause damage. Q. Can the squeak damage pads or discs? Q. Can brake pads squeak due to moisture or maybe dust?
    Any thoughts?
    Prado GXL 2012 Charcoal - Drifta Drawers, Cargo Barrier, Sidewinder Dual Battery kit, Ironman Bar, Narva lights, Safari Snorkel, Airbags, TX3350 kit, Waeco CFX65DZ - often seen with Thule 2.2M narrow roof pod and towing 2014 Kimberley Kamper. Could be anywhere!
    Sounds like a common enough problem and Toyotas response seems reasonable. I imagine you tend to fairly light on the brakes, that's usually what causes it.
    Really standing hard on the brakes once in a while will help, otherwise it's just an annoyance rather than a problem.
      I've only got two suggestions, but i'd have thought Toyota techs would have checked them. 1) Brake pad wear indicator rubbing on the rotor, or 2) caliper pistons rubbing on brake pad backing plate.
      Mike
        Having said that, Andrew knows a helluva lot more about mechanics than i do :-)
        Mike
          There are a few things that cause noisy brakes. Assuming all is ok in the brake area, everything tight, plenty of pad, etc. the first place I would start would be glazing of both the pads and rotors. Deglaze the pads, a very light skim off the disks. Refit them all correctly and all should be good. Like AJ120 said, unfortunately it is mostly driving style that causes this noise, that and cheap nasty brake pads. Stick with either bendix or genuine pads in my experience, others are ok but stay clear from cheap stuff like silverline or calibre.
          [LEFT]Silver 150 Facelift
            Thanks for the responses folks
            I appreciate your advice
              Was browsing old posts and thought I would update this. Toyota fixed squeak problem by removing sharp edges of brake discs. Fixed.
