Rotor and Brake Pad Recommendation ?
    Any current advice on pads & rotors to use? Are the T2 or T3 better?
    Hey,
    I can't feel the difference between T2 and T3.
    T3 are cross drilled, so if you are worried about cracks later on, T2 might be better.
    Best
    Mark
      Sorry, no, T3 are not cross drilled.
      T2:
      T3:
      I have T3 front, T2 rear.
        Woops!
        Sorry I was meaning these;
        http://www.dba.com.au/dba-part-finde...2)_03/03-08/09
        I can't feel the difference between these and T2 rotors.
        Best
        Mark
          I've been running T2's for QMF pads for the last year and they are excellent and the pads are giving of minimum break dust.
          2010 Prado 150 GXL Diesel, Cooper AT3, ARB compressor, Catch Can, Redarc BCDC 1225, Projecta DBC150, Optima YellowTop and RedTop D34, Pioneer Backbone Platform
            Different internal vane pattern from memory. All good.
              Ok. So I have the car serviced at Toyota and I was getting an annoying squeal at low speed asked them to check if all was ok. I am using T2 rotors and genuine pads. They tell me pads have around 6mm and the rotors have heat marks on them and are glazed. Advise was to machine them. The rotors are 6000ks old. I do not tow anything and have been off road once in them.
              Any advise, why would the have heat marks? should I change out the pads to an aftermarket brand?
                I had that happen on my sons focus after a pad change .. got the same outcome “heat marks” my mechanic said can skin the rotors but suggested they’d Bed in and all squeal would go.... it did in the space of a week or so. Not quite comparing apples with apples but the principle is the same. Different story if the rotors are warped though then in get them machined for sure
                2018 VX Prado
                  Thanks Pradosaur.
                  My thinking was that the genuine pads are on the soft side and probably heating up during everyday driving. I think when I get new pads I will skim the discs. The squealing is extremely annoying.
                    If you're planning to use aggressive brake pads, buy good rotors. I've got street track pads which are only half worn however my rotors are down to their wear limit in 25000km. Car stops very well even when towing however too expensive to go for these pads again due to needing new rotors every time. Buying good high carbon rotors also blows the cost out.
                      It is always interesting when you get a report like this....
                      so heat marks ? They’ll put new rotors and pads on and every chance within 10k - 20k you could be in the same boat.
                      Best determine any underlying issues that have caused this in the first place. Rebuilding calipers is a good place to start.
                      machining slotted rotors, I would nt bother
                      it’s a painful exercise but if you are keeping the car, rebuild calipers, use T3 rotors ( much better than T2s ) and decent pads
                      long run it will pay off not only performance wise but also $$$$
