G'day all,
Looking for anyone else who may be able to shed some light on this.
Had a service done last week and since then the brakes have been acting really weird. The service involved the replacement of a CV boot so the brake calipers came off but apparently weren't opened.
Anyway since then the first time I hit the brakes after not using them for a while (>30 seconds) the pedal is very soft and there is a lot of travel before they kick in. This is mostly prevalent at low speeds. Subsequent brake usage is completely normal if the brakes are used again within a short time. Once the brakes go without use for a little they go back to soft for the first push.
When stationary if I apply constant pressure to the pedal it sinks slowly to the floor.
There are no leaks on the brake lines and fluid is full and about 80% condition. This issue has come on suddenly.
It went back to the mechanic today and the brakes got bled but still the same issue. All my other research suggests that the master cylinder is failing but I can't find any mention of anyone else that has had the same issue, nor can I find any parts online which suggests to me that it is a very rare thing.
Can anyone point me in a direction as to anything else to try before I go chasing a master cylinder which i have a feeling will be big $$
Cheers.
Cheers.
