After about 10,000kms the handbrake had to be adjusted which was done by Toyota at the service. This was again needed every 10k.
I had it adjusted by Toyota prior to the Cape run (30k service) and after travelling from Brisbane to the Cape the handbrake would not hold the car. I stripped the rear wheels off the car and removed the brake drum/disk. Gave them a good bath and refitted the drum/disk. There is a small hole in the face where the wheel bolts on to adjust the handbrake on each drum/disk. This needed a lot of adjustment but it adjusted up OK.
There was a bit of scoring on the pads from the dust held inside the drum. Perhaps this may need to be watched when you are doing off road work and make sure we can give them a clean on long dirt runs. Might be a good idea to take some bolts so you can get the brake drum/disk to separate as mine were very tight.
Nifty.
Nifty.
