Vibration in gearbox auto
  • Vibration in gearbox auto
    2013 gxl d4d 5 speed auto has just started vibrating from the trans I think. It's just Clocked 20'000, when you accelerate from stand still just casually and get to around 45 to 50 kph it seems to change to 5th and this wicked vibration comes through it goes away if you accelerate a bit harder but it is painful just putting around at city speeds because she's vibrating. Spoke to big rock toyota service advisor to ask if he's heard of this and what I should do he said bring it in and they will have a look but he's never heard of a prado doing this before I'd guess he has but just couldn't be stuffed spending a few minutes explaining. Has anyone got any opinions on this?
    Could be engine lugging combined with a few things loosing up a bit. If you do the ECU update it won't shift to 5th until 60km/hr so this might take the vibration away.
      ok the update sounds like it could be the go, its in for its 29k at pmg karratha next month i can put up with it a bit longer, thanks for the heads up.
        Hey Toyota are saying there's a ecu flash for a 200 Lc series but nothing on a 150 Lc
          There have seen several updates for the 150 series to address various issues e.g. 2400rpm hesitation and surging at speed whilst cruise control is engaged.
            does anyone have the exact details because toyota flat say there has not been one since 2011
              The 2400rpm hesitation was fixed using:
              TNS63/11 Hesitation on downshift under acceleration.
              It was issued on 26/08/11
              This is the thread http://www.pradopoint.com/showthread...round-2400-RPM a word of warning on this fix it WILL make your truck use for fuel around town, typically up to 14 - 15ltr/100km (worse case)
              The surging problem is fixed under TNF52/12
              This is the thread http://www.pradopoint.com/showthread...hlight=surging
                I have had all the ECU updates with no negative impact on fuel use, and the car gas done over 60k so I have a good feel for the average.
                [B]Steve[/B]
                  What engine rpm are you doing when the vibration starts?
                  1600?
                  It isn't just the normal intake vibration is it?
                    Steve, when does your car select 5th, does it hold 4th till 60km/hr?
                      Vibration has disappeared and I haven't touched a thing?????
