Auto Tranny Torque converter lock at 60km/h
  • Auto Tranny Torque converter lock at 60km/h
    hi
    When i drive on a flat surface my torque converter locks cuts in and out at 60km/h. It also seems to be hunting alot.
    At 70km/h and above it locks and stays locked unless i have a decent incline.
    are any of you experiencing the same thing? Is this normal ?
    Yep, because the torque load in 5th at that speed is too great so it breaks.
    You could shift to S4 and it will stay locked longer.
    Don't worry about it, just ignore it and let it soet itself out.
    [/CENTER]
      Agree, normal behaviour. The tranny is just sorting itself out, however as Symo suggests letting it hunt is not good either so in some situations (going up hill for instance) you may need to slip into S mode and force it to stick in the lower gear, remember though when you shift to S4 you are dropping down a gear as well as out of lockup so there will be a larger increase in revs than just dropping out of lockup.
      Kev,
        Same here even with the four speed auto, in 3 stays locked from 40km/h but in D keeps hunting, then after 70km/h stays locked
