150 auto transmission oil cooler install - Davies Craig 678 with fan and thermo switch
  • #46
    What Automatic transmission fluid are people using to top up their oil coolers?
    I am having trouble getting 1 litre bottle of Toyota WS ATF, can only get 4 litre.
    Toyota Prado 2013 MY14 | GXL Auto |Liquid Bronze|BFG Tyres|Still waiting for ARB Bullbar
    • #47
      Hi All,
      I fit these brackets up today and they line up perfect.
      Thanks Tin for a great product... Well done.
      VZ
      2012 Pearl White VX, 3.0 Litre D4D Auto, Wynnum 2.5T Tow Bar, OME Lift, TJM Airtech snorkle, TJM diff breathers, Redarc EBRH, Projecta DBC100K, Lightforce XGT, EBC Nudge bar, Custom Recovery Points, TG150, ARB compressor, Pioneer Platform, Kaymar #K7123 /CDQ2195, 697 A/T's, Tin's DC trans cooler, MaxTrax on TraxRax, TJM DBS, Piranha Tray...
      • #48
        My brackets arrived in the post yesterday.
        Easy purchase.
        Thanks Tin.
        ZR
        [url]http://www.pradopoint.com/showthread.php?28607-GUV-s-ZR[/url]
        • #49
          oil cooler brackets
          Originally posted by Tin175 View Post
          I've had a few requests to supply the brackets I used in my install.
          Brackets are lasercut 2mm stainless steel. Bracket kit will include bolts and nuts. These brackets suit the Davies Craig 678 cooler. I have also provided holes for mounting the thermo fan if you want the extra protection.
          Cost will be $40 which includes 2 brackets, fastners and standard postage in Australia. If there is enough interest I will post up a new thread in the For Sale section.
          please put me on order for a set!
          look good
          Spike
          • #50
            Tin, plucked them out of the mailbox this morning. Absolutely perfect. Many many thanks. Michael
            • #51
              Tin, Any brackets still available. Sent a PP earlier with postcode etc.
              Jeff. 2013 GXL Diesel. ARB Bar, Safari snorkel, Tigerz 12000lb winch, OME 2" lift, Aux battery with CTEC 12v -12v and solar charger, 100w solar panel, Rhino bars, shovel holder, Oztrail canopy, Maxtrax, GME 3220, Toyota tow bar, Tekonsha Prodigy, Hema navigator, Tyredogs, Waeco 50l fridge, ARB compressor, Rear door table, Fire extinguishers front and rear, cig plug and 2 Anderson plugs in rear.
              • #52
                Thanks Tin. My brackets arrived in the morning and had unit fitted that day. Brackets lined up very well and look nice and robust. Great stuff, cheers.
                • #53
                  I too blame the ScanGauge. Just fitted it a couple of days ago. Today we saw 120 degrees at the torque converter coming up the hill to home on a 26 degree day. I'll be very interested to see what it is towing the caravan (~1800kg) up that same hill without the additional oil cooler.
                  We've towed the van some fair distances on 35 - 40 degree days. The Prado is due for a 70,000km service soon so based on discussions here we'll get the auto transmission fluid changed when it goes in.
                  [COLOR="#A9A9A9"][B]2011 Prado 150[/B]
                  SmartBar, Kings springs, Bilstein shocks with a ScanGuage on the way.
                  Occasionally tows a 14.44 Jayco Expanda Outback[/COLOR]
                  • #54
                    120 Transmission cooler bracket - a/c pipe support
                    Originally posted by rorza View Post
                    Me too. Matching your pictures with mine I thought it would be a perfect fit, but it seems That there is a bracket (circled in red) for one of the AC pipes that would foul on Tin's bracket. Do all 120s have this AC pipe bracket to anyone knowledge?
                    [ATTACH=CONFIG]18701[/ATTACH]
                    Any way we could get a fit up for the 120s as well, Tin?
                    Had a look at a 120 on the weekend. It just needs an extra bracket to support the air con pipe. I'll get a few cut with my next laser cut order if any 120 owner's are interested.
                    • #55
                      Put me down for one 100%, Tin!
                      Bet you Blake wants one too!
                      • #56
                        Dammit I made a bracket up and fitted it today!
                        Blake
                        • #57
                          I'll take a set too!
                          • #58
                            Me too. How is the production schedule?
                            • #59
                              The Craig Davies 678 cooler seemed to be a popular choice. It can be had for around $150 which is good value considering it comes with hose and fittings.
                              Just wondering what the reason is for picking the 678 over the 677? The 678 is listed as being for 8 cylinder vehicles whereas the 677 is for 6 cylinders (according to Supercheap website). There's also a 679 which is listed as being for 4WDs.
                              677 - http://www.supercheapauto.com.au/onl...ecommendations
                              678 - http://www.supercheapauto.com.au/onl...ecommendations
                              679 - http://www.supercheapauto.com.au/onl...ecommendations
                              Is the fan really necesarry if not towing?
                              • #60
                                Torque is the key. The D4D punches out over 400Nm so the V8 cooler is a good match.
