Auto trans oil level
  • Auto trans oil level
    Alright, so I have searched the forum, searched Google and have got nothing.
    How do you check the transmission oil level on the auto 150 series D4D?
    I know it's sealed for life, but I want to carry out a trans service but need to know how to check the level.
    Thanks in advance
    Thanks in advance
    Plug in the scan tool, get it to the correct check temp, open the plugs fill till it drips out.
    40-45 degrees.
      There is a thread on here somewhere as I've used it before. Will look for it....
      Here you go: http://www.pradopoint.com/showthread...ans-oil-to-use
      In particular:
      http://www.lcool.org/technical/100_s...fluid/auto.htm
      2009 GXL D4D White Auto - ARB Duluxe Bar - Lightforce 240 Blitz spots - Icom IC440 CB - Bilstein shocks, Lovells 1.5" lift H/Duty coils - Polyairs - Tracklander Alloy roof cage and ladder - Maxtrax - rear work lights - PP Rear-door-table - Underfloor water tank - 275/65/17 BFG AT's - Ranox dual battery system - Rear door spacer - Safari snorkel - Steel sliders - ARB front and rear air lockers - ARB CKMTA12 onboard air compressor...
        You will find the temp varies a little depending which model you look up.
        There's not much in it.
          I used an ir temperature gauge instead of the scan gauge.
          [B]Steve[/B]
            Cheers guys, yeh the scan tool is the most accurate but I understand it's not the most critical point.
            I believe you can use a scan gauge rather than a genuine Toyota scan tooll
