See more
See less
Method of flushing transmission
  • #31
    Can someone post a pic of the filler plug on the gearbox? What i can find looks like a big grub screw with a flat tab sticking out with a 23-24mm locking screw over the top. Is this the filler? Seems strange way to do it
    • #32
      Depends what box you have but that doesn’t sound like a filler plug.
      Mine is a 5-speed and filler is RHS well towards the rear of box, about 50mm higher than the sump gasket line.
      24mm thin head hex filler plug with “O” ring seal.
      • #33
        Found it. Will give it a crack this weekend
        • #34
          On the 5 speed auto, is it the higher hose on the radiator that is the return line?
