Which is more useful transmission info - torque convert temp or oil pan temp?
  • Which is more useful transmission info - torque convert temp or oil pan temp?
    Hi all. I am setting up my ScanGauge and am wondering which of the two temp sensors mentioned above provide the most useful information especially when pulling loads. Advice would be welcome as to what are members use.
    Probably both. The TCT will fluctuate http://www.pradopoint.com.au/showthr...emperature-D4D
    Nice video of how the Torque Converter works
    https://www.youtube.com/watch?v=z5G2zQ_3xTc
      The two auto transmission temp gauage options on the Scangauge 2 seem to be either the auto transmission "oil pan" temp sensor, or the auto transmission torque converter temp sensor...and after displaying them both simultaneously for a while I have now decided to only display the Torque Converted temp, as its seems to react quicker and also seems to read higher than the oil pan temp in many instances from what I have seen, so to be on the safe side, I now permanently display the Torque converter temp (and if I want I can just push one of the gauge display buttons and have a look at the oil pan sensor), but I find its mostly either close or just below the actual torque converter temp....so that's what I've decided anyway....auto transmission torque converter temp is constantly displayed
        How many sensors does the 120 have?
          Thanks Guys. After reading the replies, I think I will go with the torque converter temp.
