Diff lock
  • Diff lock
    I have the 2018 prado with factory rear diff lock.
    Is it worth doing a front e locker as the vehicle already has a rear locker?
    Can driveshafts/cv’s cope with lockers?
    Does anyone know if the factory diff locks are good bad or average?
    I guess you could add a front locker , problem though will be making sure it unlocks when the rear diff unlocks. a simple relay across the rear locker coil will fix that. Toyota driveshafts and CVs are quite large im sure they can handle the stresses while off road. Factory units work well off road , LSDs suck in comparison.
      That depends if the front has traction control whilst the rear diff is locked. Some 4wd's do, some turn it off making the front totally open. If the TC stays on I say leave it and save ya money.
      I'd see how you go offroad first with just a rear locker. Rear is what most people do first anyway.
        yeah but if you were in a situation where you would need the rear locker then you would have traction control disabled anyway??
          does anyone know if the factory diff lock could be hot wired to lock without the factory module & wiring?
          (converting it into another car that doesn't have a rear locker)
            the factory locker is just a 12v operated coil so yes i guess you could do that. There is a switch on the side of the diff but that just tells the ECU when the locker has engaged
              is this a kakadu with air bag rear suspension? or the coil spring version ??
                Hi guys.
                Im looking to buy a new 4x4 and will probably go with a Prado. i have a few questions though.
                The auto model GXL comes with a rear diff lock standard but cant find any info whether it has a lock in the centre diff/transfer case.
                Does anyone know if it does or not?
                and by the sounds of it it has a selector switch to go between 4H and 4L so is there another to activate these diff locks?
                There are lots of beautiful beaches and dunes with soft sand here id like to know its capability.
                Thanks, in the small(ish) town im from they dont even have any new model prados in stock to look at or id satisfy my curiosity myself by test driving and asking questions haha
                  Yes, there is a round selector switch for 4H to 4L and push button switches for the center diff lock and the rear diff lock (seperate switches).
                    Has anyone here got any recommendations for an e-locker installer in Geelong? (150 2011). Cheers
                      Razorback did you end up doing this? Curious into looking at retrofitting also
                        yes i did, worked well, i am about to taking out of the 120 as i am getting it ready to sell, have a 150 series, so i might fit it to that,
                        i have now purchased a 100 series and have just located a factory rear locker for that car , so will be doing the wiring for that as well
                          sweet! i am keen to look down this line too. what donor car did you get from and put into? full rear axle change out?
