Being a bit pedantic and risking starting an argument I think that the first point in the above is incorrect. There will be a small power increase equal to the current by the voltage increase. At 50 amps the increase will be about 30 Watts for a 0.6V voltage increase.
(Andrew, I agree can I have my gold star please? Maybe I forfeited it by this post though!)
Prone
Probably should have qualified the statement with maximum output power.
The alternator will have either output rating specified either in amps at a voltage or Watts,
ie it maybe 12V@100A or 1.2KW, the rating takes into account rectifier currents and therefore their temperatures, winding temperatures and the ability of the alternator to shed its heat load etc under ideal circumstances.
If you increase the charge voltage then the total current drawn must reduce to keep the alternator within its design specification, this really is a moot point though as most alternators will produce their maximum output current at quite a low voltage ie 12V, this voltage is well below the drop out voltage of the regulator, therefore a booster diode will not have any affect on the alternators maximum current output, it will only affect the alternators maximum voltage.
FWIW, I now have a Allrounder MRV70 as aux in a 2014 Prado GX sitting on a 305mm battery tray of ebay. Although the aircon pipe is gently shifted by about 18mm it is securely attached to the supplied new bracket and has a min of 8mm clear space on the full length of the pipe. Mat from online batteries came by with a set of 260mm and 305mm batteries to test fit (great service) but the MRV70 seemed to be the best match for the tray. No movement and perfect fit. A strong top bracket additionally secures it to the front guard. Now me and Prado can get cracking...
You don't want any cracking... Good work.
What an amazing transformation it has been, from someone who admitted knowing little about batteries a few days ago to now being a battery and dual battery system expert
Batteries are not complex, the problem is knowing the different electrochemical reactions. That - as you said - the manufacturers don't reveal much, its not straightforward comparing things.
As far as dual battery issues - that's pretty straightforward too except for the Prado's weight restrictions, and the variance in people's demands and camping habits. But add a camper trailer or a van (as I have now decided to buy) and then things get really complicated. Not because of battery issues though ... more because of demand and charging constraints.
For me, its basically a bottleneck analysis (something I've done in major manufacturing installations for many years), weight, cost issues and also available re-charge capacity.
I don't want to tow weight but I want to have the works behind me. I'm stuffed already, really.
Another thing that annoys me a touch, is that the capacity of a battery and its cost, is not linear. For instance, one pays little more for a similar brand's similar type of 75 AH battery, as their 100 AH battery. Very annoying IMO.
And also, differences in stats from manufacturers cannot always be explained, and also, can be simply wrong.
An example that I queried a few months ago, was the Marine Pro 620 and 730's weights. And no one told me their weights - which was disappointing. I eventually rang the company, and they agreed that their web site description was wrong. But ... they still have not changed it. So the 620 & 730 have different weights. Such things are quite frustrating.
Oh and by the way - when the battery tech issues were discussed (about Lithiums mostly), I knew about the CSIRO's new tech battery, but no one has mentioned it. It's going into production in the US soon I hope, its very clever yet a simple idea.
I actual have a Optima D27 as a start battery and a Marine pro as the aux, the Optima depending on how you use the vehicle is not an ideal choice for a cranking battery but was put there for evaluation purposes. The Optima may provide higher CCA but in my observations this has not been the case, and due to its lower Ah capacity is not a good choice if your vehicle is garaged for long periods.
The fact that a battery has a maximum recommended charge rate of 20 - 30 amps doesn't mean that is the maximum charge rate the battery will accept, it is purely a warning that it shouldn't be charged at higher than that rate, all large capacity lead acid batteries will pull higher than 20 - 30 amps in a highly discharged state, the manufacture is simply advising the current should be limited to less than the max allowed.
I have one too. I don't like its recessed top and its poor packaging. Its worked pretty well though. I'd not buy another but for the promise of fast charging, but that comes down to available charge issues, I've not worked that out, I've haven't had time, been away, and am going away again tomorrow.
You say less capacity, but Optima say that their AH rating is a 100% usage rating. In other words, their 66 AH rating provides a full 66 AH until the battery cuts off (10.5 v I guess). Therefor, for your comparison, you need to rate the 27 Optima at 82.5 AH, rather than its labelled 66 AH.
Check their Australian website.
You'll screw your battery if its just left. The car's natural drain varies, but another real issue is that despite a VRLA battery self discharging monthly at typically 3% at 25 degrees, manufactures say that they should not be stored for more than six months without re-charge. Interestingly Optima say their shelf live is 15-18 months. But we can all be skeptical of that claim I guess!
MelbournePark,
Relying on manufactures specs is fraught with danger, after doing acceptance testing for various companies for over 40 years I can tell you that seldom does equipment meet the manufactures own specifications...
I personally would not recommend any battery to another unless I had tested the battery in vehicle and had logged hard data to prove the battery performed as expected.
You keep saying the slower accepting marinepro to an AGM, I assume you have read somewhere that AGM's charge faster than flooded batteries, some do many others won't, if you took the solid separators out of a 720 and replaced them with glass mat would it now charge faster? There's a lot more to a batteries charge acceptance than glass mats.
You mentioned something along the lines will a 620 charge as fast as a 730 but can't find it again, they are basically the same battery just different plate count, therefore the 730 will have less surface area and peak recharge currents will be lower, however it is also a lower Ah capacity therefore one would expect it to be take similar or possibly less time to charge than the 730, only way to tell is by actual testing.
Charge discharge curves, discharge curves are readily available from most manufactures, Optima being the exception unless they have changed recently.
Charge curves, don't recall having ever seen one but then haven't gone looking for them as it pretty pointless from a dual battery perspective as the charge voltage, available current, wire dimensions, number and quality of connections are going to impact charging significantly anyway. Better to do some actually real time testing.
The problem with actual testing is that battery companies do it with statistical reliability. Some organisations also do bulk comparative tests. I put in production lines, very many and huge dollar amounts, and its not possable to test all the components. I have to rely on data, as do the manufacturer of machines in lines. When its built, final runs establish faults, and reputation for companies counts a lot in the reliability of their data and devices. Curiously Americans will buy Japanese lines and machinery, and will strip the Japanese electronics because they trust American electronics. Compared to all that a battery choice is pretty straightforward.
With the poster querying, no one assisted him. So I posted. I knew that if I was wrong, a fault would be pointed out.
But for experts to cherry pick and criticise via mis-quotes, yet when someone wants a confirmation on a system - and then no one posts - IMO I did the decent thing.
And I am not profiting from it. Unlike others here, I am not selling devices or installing systems. Which perhaps, makes some people biased in that it appears to me that when few brands are mentioned by people selling gear, I get the feeling that they are simply pushing a couple of brands.
As far as Optima and charging goes, they do publish lots of data. But to get it, you have to read page two. It's that easy.
As far as charging goes, I'll provide a bit of the data from Optima about charge times.
At 25 amps, the majority of their yellow tops charge at the same time - 140 minutes - from zero to 90% full charge:
D35 16.6 kg 48 AH 140 minutes
D75 17.2 kg 48 AH 140 minutes
D34 19.5 kg 55 AH 140 minutes
D34M 19.8 kg 55 AH 140 minutes
D27F 24.1 kg 66 AH 140 minutes
The D31 at 27kg 75 AH takes 210 minutes.
The D75 is actually the D75/25 ( the extra number made it difficult to read).
Give those 50 amps and they'll do it in 75 minutes, and 100 amps in 35 minutes.
That data is current, but the data comes from mostly 2008. I presume then that the battery electro mechanical reactions hasn't changed since then.
An issue with high charging, is the Christie chargers, made near Sydney I think. They have several 12V chargers, two Honda petrol ones cost around $1,400, and produce 80 and 120 amps. Since a fridge and lights use typically around lets say 50 amps a day, one of those things would only require a fairly short run, if the system could take advantage of it. With an Optima, I think temperature would be a big issue.
With more batteries though, the amps are distributed, and there's less stress on the batteries. But it costs more to install, the batteries cost more, and they weigh lots more. Darn ...
I've not talked to those Christie guys in Sydney, but I reckon they'd recommend the way to do it. Some time I'll ring them and post, but if someone else does, please post, I'd like to know what they say!
However - if over temp, batteries like the Optima are destroyed. Some US batteries have temperature limits built into their batteries! Its a shame Optima don't. I've read quite a few reports of temperature issues with Optimas in Queensland, from caravan site threads. Incidentally those charging stats are at 25 ambient too.
The interesting batteries are the ones I've left out. Namely the D51, and another which I'll mention.
The D51 only weighs 11.8 kg, yet has 41 AH. It recharges at 25 AH in 130 minutes. The attractive thing though, is that its so light. I'd like to weigh one. It also has more ohm resistance than other yellow or blue top batteries (I never inputted data for the red tops). So its design must be different in some way, but I don't know what.
Now, that 41 AH is equivalent to 51 AH in other deep cycling batteries. That's a good weight performance. Its a shame its close in cost to all the other yellow tops.
The other interesting battery is the marine - blue version of the one you have - the D27F. So, the 27M.
The marine blue 27M has the same AH capacity, less starting power, and it takes 24% longer to charge. My conclusion is that if I were to buy an Optima for under the bonnet and was willing to have 24.4kg, I'd put in that blue marine one, because I think its more deep cycle orientated. Optima seem to say that too. My guess is that the way the lead is wound or spooled is overall thicker, hence the lower starting power and also the slower charge time. I also think having an extra set of posts which the blue tops have is a benefit for many of us.
It would interest me too, to see the insides of the 27M compared to the D27F.
But for me, a more attractive AGM battery is an Exide, which seems tougher on a several grounds. But the tougher they take charge slower, due to their plate design.
As far as your own testing goes, one test may not reveal much. Especially the effects on the battery from high amperages. That a battery can take a high amperage may simply mean that its got a good CCA capacity ... but hitting it regularly with high amperages may be hurting it.
With respect Leigh - perhaps such tests may not establish reliability or certainty? I think the reason manufacturers are reticent to provide all their data, is due to the variances of loads etc, so much that they fear reliance on their data which as you say, rarely meets individual demands?
Anyhow ... I hope I haven't been rude or offended.
I'll be away for a while, so excuse me not replying for a couple of weeks perhaps. Cheers.
UNBELIEVABLE, that is the only way to explain your posts.
That one single line clarifies why you have posted up so many erroneous statements.
You have been LOOKING at battery info on the web for five minutes and your are now the worlds leading expert on the subject.
Talk about ignorance is bliss.
For example, you go on about how Optima batteries can be damaged from high current charging because they will heat up, then you rant on about 80 amp and 120 portable batteries chargers as if these would cook an Optima.
To cause an Optima the heat while charging you would need a charge current of 300 or 400 amps, not the low charge currents of those potable chargers or of any alternators.
I have an Optima Yellowtop D34 that, over the years, has been constantly charged with high currents, and was used because I needed something that would draw high currents while I tested new Isolators.
The battery has been in three different vehicles, being use and abused as an auxiliary/test battery, it on two separate occasions, sat around my workshop, untouched for many months and is now and has been my wife’s Toyota Seca’s cranking battery for the last 2 years and the battery is still going strong even though it’s now over 9 years old.
You have continually and erroneously rubbished products, based on nothing but your pure ignorance, and you have the hide to accuse manufacturers of posting up lies?????????
You are an overnight expert in a field you know nothing about!
For example, you go on about how Optima batteries can be damaged from high current charging because they will heat up, then you rant on about 80 amp and 120 portable batteries chargers as if these would cook an Optima....
No - I am interested in such a charger for charging at the campsite, with a Camper Van. A quantum / Kimberley / Australian Campsite / VistaRV or something like that. Some of those churn through the amp hours.
Batteries are simple chemistry and physic, I did both at year 12 and won a full scholarship to Uni. The chemistry in lead acid hasn't changed much, mostly in valves and the use of glass fibre, gel, and the construction issues. You don't like non professionals but I can find things out too, and i have consulted for a major manufacturer here.
Your good at attacking personally but its best to be attack the facts rather than the person IMO.
As far as Optimas go, they are the ones who talk about voiding warranties if over temp. And it makes sense. Also other AGM makers do much the same, in varying degrees. For instance FullRiver say their's should be heat shielded if in the front (I'm not sure if doing so would make a long term difference). Some don't allow some of their AGMs in the front. I have two Optimas in the front in two of my vehicles, one a 90 series petrol Prado. I had to use filler to pad out the recess to allow the factory battery braise to fit the battery. Its the 66 amp one. I have a 55 amp one too in another vehicle. Both bought in the last 18 months. Both unlike yours, made in Mexico units. I noticed too in the RX Lexus, the 55 appreciated a smart charge, which I do now on occassion. Maybe the RX needs one of LeighW's voltage fuses? The RX has started short trips and with its heated seats etc etc its no wonder the basic factory battery gave out in 40 months.
I did not say lie - you are lying yourself in making that claim.
I queried the battery weights on this thread. You - the expert - did not correct my weight estimation. I had thought the 730 would weigh close to 30kg, due to the weight of the 620 being 24 kg.
I have queried the manufacturers, as recently as last week, and also, 10 weeks ago.
But the error is still there.
For Prado buyers, the error is important.
The 620 weighs a bit over 18 kg though. But if it weighed, 24kg, then that would mean the 730 weighed around 30kg. In fact it weighs 24kg.
Its obviously a mistake, but it hasn't been fixed. And they continue to publish the wrong figures which for Prado owners who appreciate light weight is IMO annoying.
Granted to most its irrelevant but this Is A Prado Thread. Prado owners want to accurately calculate the battery weights for their under bonnet batteries.
Maybe you can fix it though? I can't as I've tried two times and haven't got anywhere. And I am going away.
Yes manufactures only tell you the good side, the things they don't want you to know are they hide away in reams of text or obscure references, it is called muddying the waters.
I haven't tried it but I would be surprised if you could start a Prado with and Optima discharged to 15% SOC but again I haven't tried it. Personnel observation is the Optima cranked the Prado faster when it was new, After a few days similar to the old cranking battery, old original cranking battery would fire the car up after 4 weeks or so the Optima won't.
Optima say a lot of things on there website but don't show data to support it. Yes they state on the Australian website discharging the battery to 0% SOC won't hurt the battery, interestingly I don't think they state that on the American website from memory. Try getting a depth of discharge versus expected life cycles graph out of them. I never could they just respond with that is sensitive commercial information. One would think if it is as good as they say they would be happy to spread the news. Personally I would not be discharging it to 0% SOC on a regular basis.
Drive safe may have more input regarding depth of discharge versus life cycles as he appears to have used a lot more of them than I have.
