Alternator Output - Diesel
  • Alternator Output - Diesel
    Ive done a search and only come up with the V6 specs. Anyone know what the output of the diesels alternator is? It is not listed anywhere in the owners manual.
    Thanks.
    This is for the 120, I believe it is same for the 150:
    12V 1.6kW
    90A or less at 11.5V
    Voltage regulator 13.2 to 14.8V
