With 150's starting to exhibit inner guard cracking, I am reluctantly reconsidering my under bonnet battery options. In my research I came across lithium ion automotive batteries and was curious to know if anyone has used these and are they worth the money?
The main benefit offered is significantly less weight (100ah @ approx 15kg), but apparently they charge extremely quick with a reasonable input voltage (about 13v). I am unsure how they would handle under bonnet heat or even if they can be installed in high temp environments. The biggest down side is the cost, with most well over $1000.
