Fitted up my Baintech volt / volt meter today. Postitioned it near the 4wd selector switch in the vacant blank. Bit of mucking around to dremel away the reinforcing plastic behind the fascia but not too hard if you take it slowly. The hole left after removing the blank is also a bit bigger diagonally than the diameter of the gauge so I made up an infill that covers those corner holes. Barely visible under natural light. I also wired the negative through a relay so the meter is dormant unless the engine is on.
