hi... this is my new post here.
i'm might be the one with unique prado here.
so, i have a 2011 prado 150 TX (japanese version)
and wanted to install a rear foglights with the switch.
am planning to make a hole on the reflector on the bottom of the rear bumper and put a bulb, rather than buy a foglights housing.
has anyone install a rear foglights on their 150 prado? was it as easy as connect the bulb to the harness and connect the switch to harness behind the dash?
also i have 2 question about confirming the right harness.
first, i found a empty harness connector next to the connector from pdc to frame harness.
(the one with the label is the pdc harness)
is this the one the foglights should be connected to?
second, which connector behind the dash should be connected to the switch?
and what is the part number of the switch as i couldnt find it on toyodiy.
thank you...
thank you...
