I'm wanting to install a Redarc BCDC unit and wondering if anyone can provide 150 series install photos / location.
Redarc BCDC install location?
Slim probably not where you are thinking but if you want to see mine in a custom battery / charger box in the back of my 150 go to my build link in my signature. BCDC1225. Happy to answer questions. I am extremely happy with the set up and the charge in both main and auxiliary batteries.
MichaelMy 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
I mounted mine by getting a plate of aluminium 3mm and bending into an L shape. One side sites under the piranha battery tray whose screws secure the battery tray and the L plate. The other side of the L comes vertically up I front of the battery. The BCDC is mounted on the front of that plate ( the plate sits between the BCDC and the battery. This location provides lots of cool airflow.
My plate also has a relay and a connector for the solar panel. The relay switches the main battery to the BCDC when the ignitions on, and the solar panel socket when the ignitions off. I source the ignition signal from the vacant fuel heater fuse socket in the engine bay fuse box (this wire has a 1amp inline fuse and holder inside the fuse box before running out the existing cable outlet then across the top of the radiatior in the same flex duct (12mm from mem) with the 6B&S which connects the main battery to the BCDC (via the relay). I have 40amp manually resettable Circuit breaker on the main battery end of the 6B&S cable.2012 Kakadu
Couple of threads for you to look through:
http://www.pradopoint.com/showthread...harger-Install
http://www.pradopoint.com/showthread...-between-trays
http://www.pradopoint.com/showthread...Battery-System
http://www.pradopoint.com/showthread...p-advice/page2
http://www.pradopoint.com/showthread...-dc-dc-charger
http://www.pradopoint.com/showthread...White-D4D-AutoMy 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Check out Off Road Down under website. They have a purpose built bracket for the bcdc 1220. It fits behind the air cleaner on the drivers side. The site has a number of pictures showing the bracket and one fitted in a 150 with bcdc 1220 attached. It looks like a really good place to fit the bcdc, very accessible too. Appears to bolt to existing threaded holes in engine bay. $30 for the bracket but looks well designed. I have just fitted a dual battery set up with ARB tray & SBI12. I intend to fit the bcdc in the future and the position of the Off Road Down under bracket looks ideal to connect the charger and isolator.2012 Crystal Pearl Prado Altitude 150 Diesel Auto. Toyota mats and rear rubber mat. Toyo Open Country AT2's 265 65 R17 LT. OEM nudge bar. dual battery set up with Optima D34, rear power points front and rear Anderson plugs. Lightforce LED combi light bar. Kingsley side steps. Outback Ideas recovery points. Dr Air Pro 150 ltr air compressor. ARB 60 ltr fridge. GME 3550s UHF radio. Hema HX1.
