Does anyone know how to remove the third brake light in the rear spoiler? I gently used a trim removal tool to see if it would lever out but had no success. Cheers
Removing Third Brake Light
Why?My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Originally posted by mjrandom View PostWhy?
http://www.comlaw.gov.au/Details/F2006L02300/Download
Download the Legislative Instrument 'DOC'
But in a nutshell any passenger vehicle must be fitted since July 1st 1989, and 4wd's since July 1st 1996.
JohnOur 6 year old and 3 year old try their hardest to make sure there is no time or money for the other baby
Originally posted by letsgoplaces View PostBut seeing (now) that you're from NZ..... still begs the question, why?
Five words, lasers!My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Gday Scooby Steve
Originally posted by Scooby Steve View Postonly to pop it out so I can fit a brake light flasher module.
If you opt to take spoiler off then make sure that you do not stress the hose for the washer jet as it looks like a total p.i.t.a if you was to pull it off by mistake.
Maybe try to trace the wire at the connector plug where the wire harness enters the door?
I can't help on wiring as i own a 120 & not a 150!
Originally posted by Scooby Steve View PostFive words? Lasers?
Seven really but no one cares about by and of.
I know I posted up ADRs elsewhere and these obviously don't apply but check your local rules. No need to attract unwanted attention when lasers prevent repeat offences.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
