Monster light M18 as DRL in ARB Deluxe bullbar
  • Monster light M18 as DRL in ARB Deluxe bullbar
    Wondering if anyone has fitted these to replace ARB original DRL's?
    Rang Monster light and they said they will but still not shaw as size is 127mm and original light is only 100mm.
    2012 BLACK 150 GXL PRADO, ARB DELUXE COLOUR CODED WINCH BAR, REDARC DUAL BATTERIES, 240 BLITZ HID UPGRADE SPOTTIES, 32 INCH LIGHT BAR, LED INTERIOR LIGHTING, HID AND LED HEADLIGHT UPGRADES, CHIP BOX POWER CHIP, 265/70/17 AT BFG, REDARC ELECTIC BRAKES, SCANGAUGE, SAFARI SNORKLE, POLY AIR BAGS, 40 LTR ENGEL, MAXTRAX, RECOVERY POINTS, ARB TOWBAR, TOYOTA ROOF BARS.
    They are camp/work lights and should not be used as DRLs.
      The Narva circular DRL will fit but you need to make up a bracket.
        Thanks mjrandom will look at these as one of mine keeps blowing and need to replace with something else.
          Are you shaw now? I'm sure you will see what I mean.
            Sure I new that, sorry early morning start and long hot days in the Timor Sea.
              The Narva lights are 90mm diameter and the ARB ones are 105 from memory. I will use a (wait for it) circular downpipe adapter which fits around the DRL nicely and also fits into the ARB enclosure. A job for a weekend soon to come. I also need to fit the TJM bash plates to the new cross member after the diff drop. This is on the C-ute.
              For the 150 the bracket was pretty easy to make up and the lights fitted into the TJM bar much easier.
                Yes, I've been looking at the round Narva ones (71940) for a while - manufacturing a solid bracket is the issue!
                Prado 150 D4D AUTO GXL with ARB Deluxe Winchbar, Brains' TG150 Transfer Case Actuator Guard, Bilstein/Ridepro 50mm Lift, Safari Snorkel, D697 265/65/17 LTs, Dual Battery Setup with REDARC Controller, REDARC Tow Pro, Toyota Tow Bar, Maxtrax - towing a Camprite TL8s fitted with GXL wheels and D697s.
                  i have used the narva delta 6led in my last two arb deluxe bullbars. only problem is u need the black plastic inserts to be fully intact as the delta is slightly smaller than the stock throw away arb fog lights. the larger delta would fit aswell but are over $300 each where i get the smaller for $150 each
                    Any pics or further info on how you went about the installation?
                      Me or Mitchell?
                        Either would be appreciated, though I'm particularly interested in the install by Mitchell, as I have an ARB bar. Thanks.
                          I installed the Narva DRLs into the C-ute deluxe bar a couple of weekends ago. I sacrificed the body of the fog lights to mount the DRLs. I have some photographs on my computer which I left at work today...
                          Fit well and the little alignment screw still operates correctly.
                            Sounds like a neat way to go - you'll have to forgive my ignorance, but what is the C-ute deluxe bar? You've got a TJM bar, right?
                              The C-ute is a Colorado ute. It has an ARB deluxe winch bar. I think the inserts are the same on all the ARB deluxe bars. My 150 (well the wife's 150) has a TJM T3 bar. I will post up some shots later today.
                              Time for the confessional, much later today. Pics are still in the camera. Oops.
                              mjrandom
                              Out of control poster!
