Good 12V Ignition / Constant source in dash area?
    Bugga that’s a useful link - presumably the fuses will be the same but I’ll check one of mine to be sure.
      Hi Snouto,
      Just bumping this thread as I do need to connect my dashcam into this fuse box via fuse taps wires as well.
      I just confirmed that it is a 'Low Profile mini Fuse'
      Do you happen to pinpoint which is constantly ON (BATT) and where should the ACC wire should go for the dashcam?
      You help guys is much appreciated.
        BAT (No break 12v power) is available on the "OBD" fuse, 7.5 Amps and can be tapped in the inside fuse panel top end of the centre row of fuses.
        In normal circumstances, it would only be used when an OBD dongle is plugged into the DLC connector, under the steering wheel / above the footwell area.
          Just want to share when I installed my VIOFO dash camera while using its HK3 hardware kit.
          I've plugged my ACC to 15A P/OUTLET and my BATT to 30A P/SEAT FR
          This is the orientation of my fuse wire tap.
            Can add to that - the blanks marked with circles at the "live" terminal are BATT options as well. No other blank is live as BATT or ACC
Name:	Prado150 Fuses.png
