Tapping into High Beam Circuit for LED Lightbar/driving lights
  • Tapping into High Beam Circuit for LED Lightbar/driving lights
    Sorry if this has already been posted but I have searched posts over the last 12 months and cannot seem to find instruction on tapping into the high beam circuit. Can anyone tell me where they tapped in and what colour the wire was that they tapped?
    Cheers............Wayne
    At the back of the headlight, there are two wires going to the high beam globe. One is earth and the other is switched power, use a test light to work out which one is the power and tap into that.
    [LEFT]Silver 150 Facelift
      I'm looking at this too, there must be something under the dash, saves running 2 wires through the firewall.
      Cheers, Nova
        Find the feed for the high beam light in the instrument cluster.
          I grabbed the trigger off high beam and ran that to 85 (or 86, doesn't matter) and from the other relay trigger 86 (or 85) ran a single wire through the firewall to the switch and then to earth. Means the lights in the switch work differently but saves running in and out of the firewall with a live wire.
            I bought the narva wiring kit. It has an inline plug adapter so there's no cutting of wires.
              If they are Scotchlocks, then they aren't very reliable. Best to solder the joint.
                no the narva kit has a plug and play adapter.
                Plug one onto the H4 bulb and the other end plugs into oem wiring.
                I used on when wiring up my light bar on my bt-50 and worked perfectly - no scotch locks and no cutting into wires.
                  That would be awesome. Need to look for one of these.
                    I don't think the facelift 150 has H4 bulbs... I've got a Narva kit and it doesn't look like it will install "plug & play". Looking around I think they use HB3 bulbs for high beam (and H11 for low).
                      i matched the high beam plug and purchased some on ebay and made up a double adaptor - one power in with two outs - one for the light and one for the switch. then i just ran twin core through the firewall.
                      if you are planning to use a switch that lights up the green wire is the one to tap into.. i found a spare plug under the stereo that i used
                        Hmmm, great idea - I was going to hack into the wiring. Instead I've ordered a HB3 extension on eBay which I should have mid week. Thanks for the tip!
                        If you're looking for one search for "HB3 socket". If you aren't in a hurry there are some from Hong Kong for $3.50 otherwise an Aussie seller has them for $11.99 (2 days vs 2 1/2-4 weeks)
                          It's plug and play. No scotch locks. The narva kit comes with two adapters.
                            Pictures please
                              If you have used the H4 connection and you have the HB3 left over, I'd be keen to throw a few $ your way for postage. I'm wiring Cibie Oscar and LED Lightbar but trying not to cut into the factory harness. Open to suggestions.
