Hi All,
I recently installed a CTEK DB250S in my 150 Prado following the wiring diagram supplied with it, Iv connected the Aux battery positive to CTEK Aux output, negative to ground and CTEK negative and connected the start battery positive directly to the main connection on the CTEK, for some reason the battery isn't charging.. Any ideas? Do I need to install an automotive relay between the alternator, the CTEK and the main battery?
