Tail lights on trailer working intermittently
  • Tail lights on trailer working intermittently
    WhenI plug my trailer into my car, sometimes the tail lights work and sometimes they don't. When they don't I can hear a buzzing sound coming from the back of my car.
    I am thinking this might be a relay for the tow plug?
    If it is a relay, is this something that I can replace myself or is it an auto electrician job?
    It's a real pain as all the lights will work fine, then the next time I plug it in, no tail lights?
    Mark
    If you look in where the jack is there should be a small (10cm x 5cm ish) black box stuck to the car with a cable harness coming in the bottom. This "drives" the trailer lights. Next time you hear the buzzing perhaps check if the sound is coming from it.
    At least that's what the Toyota tow bar has... if you have a different one it might be wired another way.
      Check the pins in the plug both sides.
      My CT pins were closed in a bit so would work sometimes when pluged in to prado but when pluged into my other car was fine just simply spread the pin open.
      Arb colour code deluxe bar, safari snorkel, lightforce venom HID's, GME uhf remote face, redarc tow pro, redarc bcdc 1240, pioneer platform, 40" curved light bar, dual battery, 3" SS exhaust, EGR mod, trans cooler upgrade, provent catch can, scangauge 2, diesel care secondary fuel filter, Tin's bash plates and actuator gaurd, 2in Bilstien and kings lift,
        Thanks Peter,
        I just had a look, I do have the Toyota tow bar and the loom from the trailer plug heads up into the jack compartment.
        However I can't see any black box.
        I'll have a play tomorrow after work or on the weekend to see if I can get it buzzing :-)
          I'll have a look Hally.
          It was doing it with the original Toyota plug on the car so I replaced it with a new utilux one and it's still doing it.
          Though thats not to say the female portion of the trailer plug isn't a bit loose on that pin.
            I have a Reece style bar fitted by Vic Park Towbars utilizing the Toyota harness. You should be getting a solid tick tock sound from the rear relay that was detailed above. If it's buzzing then the relay is shot. It's there, towards the rear of the car in that jack compartment.
              I'll have another look in the jack compartment, but I couldn't see anything when I looked earlier.
              Assuming it is a buggered relay, which I suspect, do you know if it is something that is easily replaced of is it a trip to the auto electricians?
                It's a control module (basically a box of relays). Not sure if anyone else has had any luck finding a replacement. Lumen is the company who make the towbar loom for Toyota so they may be able to help you out.
                [LEFT]Silver 150 Facelift
                  i had a similar problem in another car.
                  Turned out to be an intermittent short circuit in the wiring.
                  The control module had overload / Short Circuit protection built in. the Toyota one may be the same.
                  Easy test for the wiring check resistance with a meter and get someone to move the wiring around while watch the meter to see if it changes.
                  Second way connect power to the taillight pin with a 5A inline fuse all lights working, then try pulling and moving the wiring around to see if there is a short circuit the fuse will blow.
                  if not then your back to the control module
                    Mine is not in the Jack compartment but in a space next to it, where Toyota recommend mounting it. From memory you have to remove the side trim to access it.
                      I meant in the void between the jack compartment and the rear panel, basically under the tail lamp. I can't get to mine easily because of the drawers.
                        Just had a look and using a mirror I can see it up near the tail light.
                        I'll have a look tomorrow, that is plug trailer in and have a listen. I'll need to remove my draw to actually get to it though :-(
                        I can't not have tail lights on the trailer so should be a fun Saturday L0L!
                          Generally those sorts of things a pretty reliable, when it comes to trailers I would carefully
                          check the trailer plugs sockets for faulty wiring, and the trailer itself as it is more likley to be
                          a faulty in the wiring than the module. If possible can you borrow another trailer to see if you
                          have the same issue?
                          LeighW
                            check the trailer plugs sockets for faulty wiring, and the trialer itself as it is more likley to be
                            Thanks Leigh,
                            I'll see about connecting to another trailer.
                            I'd like to think the trailer wiring is good as I built the trailer myself I did all of the wiring making sure all joins are soldered and adhesive shrink tube covers all the joins. However I won't rule anything out at the moment!
                            The thing that is doing my head inn is I've just spent nearly an hour trying to get it not to work so I can test a couple of things but all is working fine.
                            However I on Wednesday I took it to get weighed, check the lights before I left and all was fine, got home and no tail lights.
                            Unplugged and plugged the trailer in a couple of times and it was working again, then get ready for its inspection Thursday and no lights so I had to cancel the inspection :-(
                            I'd be happy if it would just simply work or not work so I could get on with it!
                              So, I have found the source of my problem and thankfully it is not with the car, however I am still a bit confused.
                              Because the trailer has a hard wired earth through the plug I haven't had the trailer physically attached to the car today and all of the lights have been working.
                              I hooked it up tonight with the intention of driving around the block to see if that did anything, and bingo! No tail lights. Dis-connected the tow hitch and the tail lights come back on.
                              So why is it doing this and only with the tail lights?
                              Mark
