Just trying to avoid paying for Toyota to diagnose a possibly obvious problem.
On my way to the train station this morning the "Charging System" light (red battery) came on and has not gone out. The manual just says go to the dealer. From what I've read on here I'm pretty sure its the alternator, and if so I'll try to buy one a replace it myself, but want to be positive that is the issue.
I've put a multimeter on the main battery tonight and it's reading ~12.25 V with the engine turned off and the same with the engine running. The auxiliary battery is showing 12.8V. Is this pretty clearly a stuffed alternator? If not what else should I be checking?
Chris
Chris
