hi all , does anybody know if the 1GD alternator has a one way pulley and what it actually does , why its there , benefits therof , etc? Ive not played with one for a very long time till yesterday when i had to replace the alternator on a neighbour's Astra. Would you believe the pulley was not available separately so had to replace the entire alternator , how wasteful is that ???
2.8 Alternator pulley question
Clutches for previous models Prado's are available from Ebay etc, I would have thought
they would be available for the Astra, what is the Astra by another name, I assume Holden
don't actually make it?
The clutch reduces the overrun load on the drive belt, if you look at the way the belt drives runs on the prado you have the crank shaft pulley the tensioner then the alternator, if the motor is spinning at high revs then suddenly slows ie change gear the momentum of the alternator would pull on the tensioner creating slack which could allow the belt to come off as well as the load aspect on the belt, the clutch allows the alternator to freewheel and slow down without loading the belt.
Many though replace the alternator when it fails or with bigger units that don't have clutches, would be interesting to know if they have experienced any problems?Last edited by LeighW; 30-05-2017, 10:12 AM.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Originally posted by LeighW View PostClutches for previous models Prado's are available from Ebay etc, I would have thought
They were known as Opel Astra in Germany and Vauxhall Astra in UK.
You would need to check actual model numbers to see that they are the same alternator.
They seem to be about $AU40 delivered. eg http://www.ebay.com.au/itm/182374635269
There are lots of Australian suppliers on ebay selling pulleys for up to the 2014 3.0 litre but you could ask them if they can supply one for the 1GD if you ever need to.
S.
S.155 SX with dual battery and Polyairs in the rear springs..
