Alternator Booster Diode
    Hi BlokeInOz, as 120D4D suggested, give LeighW a PM, he is on this forum.
    He can give you the info about his Alternator Voltage Booster Fuse for your specific vehicle.
      Originally posted by 120D4D View Post
      He was referencing what other brands (ie nissan) do with there cutting of the wire mod...
      The only way for you to do it properly is to get one of LeighW's alternator voltage booster products. Send him a PM or check out hkbelect on ebay...
      Hey therr 120D4D, thanks for that, I'll look him up.
        Hi drivesafe, thanks also for the info.
          My pleasure BlokeInOz.
          Can you take some voltage measurements, before and after you fit the new use?
            Hi 120D4D, thanks for the info, I've now purchased one from his ebay store.
              No problems, will do - stay tuned.
                Received my fuse/diode on Friday. Was doing some other work on the steed today so I decided to install and test the results. Very pleased.
                LeighW's product is topnotch.
                13.9v with standard fuse
                14.5v with diode/fuse
                This was with cold engine with ambient 15Deg-C
                  Hi BlokeInOz and that’s a good result.
                  If you have not driven your steed much since you fitted the fuse, try measuring your cranking battery in the morning, before you start your motor.
                  Then in say a weeks time, again one morning before you start your motor, measure the voltage of your cranking battery.
                  This is where you will see the immediate advantage of the fuse.
                    Hi Drivesafe, that's exactly what I thought. I use the "steed" every day daily drive, but my normal run to work is only 5 minutes.. benefits of living in the country, I know that another can-o-worms, but I give her a 10 minute warm up most mornings due to the ambient.
                    I'm heading for Adelaide tomorrow about 5.5hrs, so will monitor the voltage as the engine and bay get upto correct temps - to see what affect that has on the output voltages.
                    I don't have the luxury of leaving the vehicle for a week without driving, and to be honest at this stage - only just got her - I don't want to, very very nice to drive.
                    I'll put up some info about my monitoring of voltages on the trip there and back next week.
                    cheers
                      Hi BlokeInOz, the reason behind measuring voltage in the morning, before starting the motor, is to see what the settled voltage is before and after you have been using the fuse for a while.
                      Your 5.5 hour drive will be perfect for seeing how much higher your battery’’s settled voltage will be, thanks to the long period of higher operating voltage while you are driving.
                      I would not be surprised to see say something like 12.3v rested voltage this morning and 12.5v or 12.6v tomorrow morning.
                        Hi, Back from Adelaide, I did some monitoring of the voltage and basically never dropped below 14.1v during all driving - and I think that is fantastic. Not sure on the battery I did a check the morning after the trip up and had resting of 12.33 (multi-meter). Not too sure on the condition of the battery as I have only had the vehicle for about 4 weeks now. I did loose a little interest in the monitoring of the voltage due to a large oil puddle under the car. - not wanting to hi-jack this thread I don't want to go into too much detail. Rang the dealership purchased the vehicle from and asked if I could take it to a local (Adelaide) dealer - who shall remain nameless. After initially blaming my installation of the "Catch Can" (which it was not the cause - as if it was I would have had to empty 12 months worth) they said they found that the oil return line gasket from the turbo had blown. Well they kept vehicle overnight and said it was all fixed. next morning - still oil but not as much. Drove home and monitored oil level. Got home and oil blown back under the whole car. Will be going into dealer tomorrow.
                        Happy with voltage diode
