Seriously, Stedi need to fix this. Pretty poor. Did you send them some feedback regarding the connector? I did. They told me that they haven't had any other issues with the connector. Felt like it was only me.
STEDI LED fog lights for ARB summit bar
Yes, I sent them the same stuff I put here.
Response!
The connector was purely added as a plug and play method for the ARB wiring.
They are ironically plug and play with most vehicles, but however, the original ARB Summit fog light supplied with the bullbars have a HB4 halogen globe fitted. When designing this fog light, we kept the HB4 fitting for simplicity.
Essentially, if your car is not pre-wired with the ARB wiring harness, we cannot guarentee it is a plug and play fitment.
Hi Lads,
This question is for those of you who spliced into the red ARB clearance cable for Stedi’s day time running lights, does the DRL come on upon starting the car? Or only when the headlights are switched on?
Also would it be possible to tap into the head lights DRL with any issues?
thanks in advance.
