HI Beam pick up
    Has anybody had any luck wiring their own driving light loom into the MY18 wiring? Or is a canbus module with some smarts required?
    Trent
      Negative switching you need relay
        Iíve just installed the Toyota genuine wiring harness with Kings lights. Was pretty straight forward, just fiddly and time consuming. Took me 2.5 hours. The Canbus wiring on the 2018 Prado means you need to pickup the trigger wire at the headlight stalk.
          Hi all, I am looking at getting a set of driving lights for my 2018 Prado. I will be using the genuine wiring kit to wire these up however the driving lights have a DRL/position LED strip on them, does anyone know what would be the best way to wire this up so they work along with the cars DRLs as i don't believe the genuine harness has allowed for this.
          Thank you
            How hard is it to install your self ? Or should I ask Toyota at the 10k service to do while there so itís itís plug and play for when I get lights and a bull bar as I donít have now but will I future when I have $
