Key fob battery life?
  • Key fob battery life?
    I have a 11/2014 prado I was about 2hrs away from home when the fob stopped responding showing the no key detected sign on the dash then with a bit of panicking it started then about 2 weeks later I went to start the car and same thing so I got the spare fob and it started so itís time to change the fob battery and put a spare battery in the glove box. I wish the prado had a good old key I hate fobs for this reason.
    so how long have people got out of there fob batteries and has anyone got stuck like I nearly did and how often do people change there fob battery?
    Did you try the emergency procedure described in the owner's manual? Those fobs contain an active RFID tag and a passive one. If you hold the fob right up to the start/stop button (with your foot on the brake) then the receiver in the start/stop button should be able to excite the passive tag in the fob, and get you started.
      The original battery lasted a couple of years and now i have replaced it with cheap ebay batteries. They are a couple of bucks each, cost about a dollar from memory and last about a year.
        I got mine from here
        https://www.ebay.com.au/itm/2-New-EN...gAAOSwPe1T4gC7
          Ha, I got some from the same seller last week. My tyre pressure monitor uses the same size so I got 10 although my fob was also flat. We leave the keys in the car all the time so I assumed it was transmitting often. Only 2 years out of the original batteries.
          Cheers, Nova
            One lasted about 3.5 years, the other one is still going well!
            D4D. How long will it last?
              Lately, I get in the car and every now and then, when I go to start it and it shows the no key key symbol even though its in my pocket. Is this a symptom of a dieing battery? Its a Dec-14 GXL.
                Just go into Toyota and get it changed Usually about $12 Last about 3 to 4 years
