Replacing a supacentre wiring kit switch with a ebay switch
  • Replacing a supacentre wiring kit switch with a ebay switch
    hey guys,
    so i have a supacentre wiring kit for my light bar. i want to replace it with a ebay switch as the supacenter ones does fit nicely or look as good.
    the switch i went with is this one https://www.ebay.com.au/itm/232235139145 ( the LED Light bar one ) the supacentre switch has 3 wires red black and white. the new switch has 4 wires two red one green one black.
    Which colour wires on the the switch do i fit onto which wires of the supacentre wires. photos attached of old switch with wiring that is on the supacentre kit and new switch and wiring on new switch.
    cheers
    Ok so got it sorted well 90% anyway. Switches arrived today and colours of the wires are slightly different. Attached is the wiring diagram and how I wired it to the supacentre harness. Only thing I need to figure out is where to connect the blue wire ( dash lights on ) cable in this case it would light up the”Spotties” part of the switch. ( I have a “light bar” worded switch which I will be using going forward. Anyone know which wire I could pull the dash lights on from?
      Most of the switches light when the lights are turned on, just use a multi meter to identify the wire involved on the switches, you will
      need to jumper the negative and the positive across. If you look at the switches two of the wire colours will be common across all the
      switches that light, these will be the back light wires.
