Help with instrument panel
  • Help with instrument panel
    Hello everyone, I have a GRJ150 VX with air suspension and I have removed the bags by springs, remove the suspension ECU, but I need help to disappear the height indicator on the instrument panel
    If its possible it'll be done through an OBD scan tool like Techstream.
    Dealers have it and might do the delete for you.
      Hi.
      ​​​​​​Today I went to the dealer, did the work with the Techstream and were not successful, any manual to carry out the process?
        Likely cant be removed. From memory they are always visible on the Kakadu dash LCD? Yes?
          There must be a way to eliminate it, the instrument panel is the same in the fields that have air suspension and those that do not have air suspension, any idea to solve my problem?
            Reprogram the ECU that controls it I'm guessing.
