Hello Everyone,
After some research I did I decided to use Redarc bcdc charger for my dual battery system. Yet what is always neglected is that such a charger won't charge properly if the battery has load connected. This is why I am looking for 5 PIN relays capable to switch more than 40A (the best would be 80A). The idea is very simple - to reconnect a whole aux load to the main battery when the engine is running (the ignition is on) and charging is in progress. I want to use a single relay if I can find any. It has to be 5 PIN to avoid solenoid current while aux load is running on aux battery.
Guys, any hints where to go for them? I found some on ebay yet 4 PINs only.
