Hi Guys,
I need to install an Anderson plug near front passenger seat. I need to run my inverter with up to 1000W load. I thought that maybe I should install an inverter under the seat yet it seems to be too far and I may need to use this inverter somewhere else.
I have to run cables (actually plus cable and use chassis as a grounding) from the engine bay all the way to that point. 6BS cord seems to be not expensive and since current density in such cord can be safely 8A per sq mm this cord seems to be thick enough. However, it is not due to voltage loss if I install anything below the sit. The path I've found - the battery, the firewall and central channel seems to be up to 5m long. I don't know much about chassis resistance so I assumed that in worst case I may need to run two cables. This is 10m of total wire lenght. Under 100A load it will be 2.6V lost on 6BS and 1.4V on 3BS. 2.6V means 10V on my inverter or less from full battery. This won't work.
So, If I can find any convinient place, say, around the glove box, it may work on 6BS cable. Yet I've been looking around for a while and I have no idea where to put an Anderson plug.
Any suggestions?
Any suggestions?
