Hi Folks, - Thought this would be a very useful thread for newbies and oldies alike - Or evolve into one anyway....
I think the title says it all - So if you have found a wire location and color that is useful for something then please post it here and I will keep this first post up to date.
EDIT- DISCLAIMER: The info below is supplied by like minded enthusiasts and in some cases not professionals in the trade, it is therefore used at your own risk to save time and would advise a quick check to verify.
Brake Light Signal
Purple Wire, Found at the plug going into the Brake Pedal.
Dash Illumination when lights are turned on
Green Wire, Found at the headlight angle adjuster switch - there are two green wires here, its the one on inside pin of the plug not the outside pin (its a four pin plug).
12v constant - I am sure there will be many different locations and perhaps differing color depending on location.
TBA
12v acc. - I am sure there will be many different locations and perhaps differing color depending on location.
Green Wire, Drivers side of the Engine Bay above the brake booster going to the wiper motors.
Brake Light Signal
TBA
Matty80
