How much FUEL can be USED in the TANK before you RUN OUT?
  • #31
    Originally posted by Matt - mr4x4 View Post
    Mate they rock ! Had them on all my cars... Brilliant.
    Just curious... What% Error have u got yours set to, to give u an accurate figure?
    rob
    • #32
      Rob I think about 49.1% from memory..
      [CENTER][B][U]Matt
      [/CENTER]
      [SIZE=2]
      [/SIZE][CENTER][SIZE=2]
      [/SIZE][/CENTER]
      • #33
        Yeah.... mine is set around the 40%. This changes slightly when I've got the Van on as well.
        I believe the latest SGII can only have a max of 20%, so I'm glad I got this one and not the latest as I don't reckon u would be able to adjust it enough to get an accurate figure....
        • #34
          Yeah, mine is the latest new one. Got about 14 months ago. It's a great bit of techo gear.
          [CENTER][B][U]Matt
          [/CENTER]
          [SIZE=2]
          [/SIZE][/CENTER]
          • #35
            Matt, has it got the latest 4.02 version software? If it has I thought they were limited to 20% error adjustment from what I remember reading about the new software....
            • #36
              I checked Rob..
              [CENTER][B][U]Matt
              [/CENTER]
              [SIZE=2]
              [/SIZE][/CENTER]
              • #37
                OK... So that blurb I read on their website about only being able to set a error percentage of 20% was obviously incorrect then .....
                I assume this new one gives u Auto Transmission Fluid Temp?
                • #38
                  My ScanGuage has the latest software and it will correct over 40% error. Yes it does do ATF temperature as well. I have read a few reports where people say that the ATF temp is not accurate but to me it seems spot on. The only question is where it takes the reading from.
                  • #39
                    Yeah mine does auto temp all the performance x gauge wanky stuff too..
                    [CENTER][B][U]Matt
                    [/CENTER]
                    [SIZE=2]
                    [/SIZE][/CENTER]
                    • #40
                      Tank capacity & range
                      Hi All
                      First time yesterday I filled up my tank full to the brim.
                      Which I assume would be close to 150L.
                      But cruising range state as only 1366km.
                      Given the my current average is 9.7L/100km (as per my display), I would think the range would be further.
                      Or do D4D actually has 150L tank capacity?
                      • #41
                        how many litres did u end up putting in?
                        I would be recording all your fills... that is your mileage at filling and litres put in your tank. From here work out your true economy and see how close the trip computer is to your actual economy... This way u will have a better piece of mind as to range....
                        • #42
                          From my history I reckon the trip computer is out approx +1L per 100km based on actual bowser litres pumped in and Kim's travelled.
                          2012 150 | GXL | D4D | Auto | Graphite | TJM T13 | X-Ray 220 HID | Genuine Towbar | Engel 40L
                          • #43
                            As above, the display on mine will say 9.4L/100k yet in reality when you refill its around 10.2L/100k every time. Toyota just want people to feel better looking at the dash readouts.
                            • #44
                              I filled the car today and it took 146ltrs... It was very empty
                              2012 Pearl White VX, 3.0 Litre D4D Auto, Wynnum 2.5T Tow Bar, OME Lift, TJM Airtech snorkle, TJM diff breathers, Redarc EBRH, Projecta DBC100K, Lightforce XGT, EBC Nudge bar, Custom Recovery Points, TG150, ARB compressor, Pioneer Platform, Kaymar #K7123 /CDQ2195, 697 A/T's, Tin's DC trans cooler, MaxTrax on TraxRax, TJM DBS, Piranha Tray...
                              • #45
                                for how many kms travelled?
