EGR blanking plate to block off or restrict?
  • OK so I bit the bullet and fitted a EGR restrictor plate with a 7mm hole.
    Absolute mongrel job! I could not get the plate to go in from underneath so I removed the thermostat housing so I could see what I was doing and put it in from the top. At least gravity is on your side doing it this way. Interestingly there is no thermostat in the housing? The water temp stays fairly constant so I guess its elsewhere!
    First drive all is good feels a bit stronger could be a placebo effect.
    Colin
    • Originally posted by Coolcol View Post
      Colin
      The thermostate is on the other side near the alternator.
      Did you remove the power steering pump bolts to allow for more room to place the plate?
      Rusty.
      • Originally posted by Ages View Post
        really appreciate your input on this thread mate.
        Can I quiz you about the one EGR thread running alongside this one, where Sbclover has removed the throttle plate, which you say is stopping the EGR draw. This sounds like a much easier mod than running clean air from the airbox.
        would you recommend one way over the other?
        any chance you might be able to fill in on what other function the throttle plate plays, if it can be removed without any other real issues it doesn't seem that important..
        No probs, happy to help.
        The throttle plate is making the egr draw, that is the primary reason it's there.
        The secondary reason is for a smooth shut down.
        So your right, it's nt that important at all.
        I have not removed a throttle plate yet, nor do I know anyone who has. When I write something here I take into account thousands of people are reading it & may act using the advice, or at least taking it on board, so I make sure it's right before I write
        So I cannot categorically say it will work & you won't have any problems. However I'm very confident it will work. But you may have a bit of a rough shut down, not sure how bad. I don't think engine light either, but is possible.
        I did attempt to remove a throttle plate so I could have it copied, so I can do some r&d & reverse engineer it.
        Was thinking more of a modded plate rather than compleate removal.
        But the screws were super tight, carboned in, I will need more time on this.
        The 7mm bank plate works well but always looking for improvement.
        If you wish to go ahead & remove it, give it a go & let us know how you go.
        It's all reversible, unlike cutting, drilling etc egr coolers & air boxes. Nothing to see either
        Anth120playdo
        Banned
          Colin
          Yes fun job hey.
          As rusty says thermostat is on other side & no you don't want to change it, that's fun too.
          The way to put a plate in properly is start fresh clean the egr as well not just throw a plate in.
          It's about 5 hrs work & much more fun than you just had.
          Remove power steering pump reservoir, & common rail plug (don't break it) they are often very tight. This allows more room, much easier if you have the egr assembly off.
          You will notice more responsive on light accel.
          • Wish i had a dyno. (and a two post hoist that was on the list for fathers day).
            Had the 7mm plate in for a couple of weeks and car feels better in low to mid revs and part throttle, but could be the placebo effect as well.
            Interesting that when slowing down, changing back to 3rd or 2nd 2500rpm or so i am showing 2.5 -3.0 psi boost. Maybe it was the same before plate but i can't remember. Anyone who has not done the EGR mod and has a scangauge can you look to see what boost you have when slowing down please.
            Rusty.
              Rusty.
              Hundreds of people with placebo affect
              Boost does hang around a little, like a couple seconds longer.
              • You guys think I will need to strip down my egr on a just under 20k km car of which 15k is with a provent?
                I ready don't have the motivation and confidence in doing this with out some good DIY pics
                Prado MY14 150 Series Altitude - Rhino Pioneer rack with backbone system, Tint, Fuel Manager Pre-Filter Fuel/Water Separator, Mann Provent 200 oil catch can, Toyota 2.5T Tow Bar, Scangauge2, TJM T3 winch bar, Narva HID 225, Polyair Air bags, 2" lift (Bilstein & Kings), Uniden 7700 with GME AE4018BK3, 32" LED Light bar, 2mt Awning, 1100mm Treds with mount plates
                • Originally posted by evltoy View Post
                  Just take off the intake elbow (front) & have a look. But then it's hard to tell how at bad it is if you don't see others to compare to.
                  It's always hard to get motivated on ths job, like most p.i.t.a jobs
                  37,000k 2014 150 series.
                  Not bad?
                  But once it's off
                  I always like to start fresh. No point putting a plate in & not knowing how bad it is/was.
                  135,000 on a 150 series
                  Getting a bit filthy?
                  Then 208,000k
                  Bloody clean.
                  So you really have to check & clean.
                  Yes it's ridiculous.
                  Preferred view
                  • I have done a few 1200km hwy trips with the boat. From what I read the egr is open while cruising so I'm tipping mine will be bad
                      Towing creates more load & egr may be more closed.
                      So it should be cleaner.
                      • I'll be doing mine in 2 weeks when I'm on leave. It will be interesting to see how much carbon is there after 20k. Is there any extra gaskets etc that I should be ordering before stripping things down? Also where is the best place to find the relevant torque settings?
                        Aug 14 150 GXL D4D Auto. BFG KO2's. Hi flow muffler. 7mm EGR restrictor plate.Bushman fridge.
                        • Originally posted by Grumpy View Post
                          You should be ok to re-use all the relevant gaskets.
                          The litte 10mm ones are 13nm. But I'm a bad boy, with experience, so I go by feel on egr stuff. The 12mm bolts & nuts, About 20nm.
                          Screw clamps 6nm.
                          The rest, you should be able to feel you way through.
                          It's more the Injectors & fuel system that all needs to be torqued to spec.
                            #### I think you mean Nm (Newton meters) not nm (nanometers)
                            Greg - 08 D4D Prado,
                            • Originally posted by Corigator View Post
                              Yep yep
                              • Is a long hard highway run (110kmh for 10 hrs, followed by a 45 steep hill climb up the snowies, then another 10 hrs on the freeway enough to help clean out the EGR? I'm going to fit a catchcan, restrict or plate and clean the EGR once it is out of warranty, but would prefer to do it the old fashioned way until then.
                                Thoughts from experienced mechs?
                                Thanks.
