EGR blanking plate to block off or restrict?
    If you are not apt, it will be one of the biggest headaches you ever had.
    Prado masochism: some of us might like that.
    • So is there a DIY written somewhere with step by step, including photo for newbie like myself to perform this cool mod?
      (i hope its not too much ask)
      • Just out of interest.....whats the advantage of bypassing coolant from the EGR?
        2016 1GD GXL 6 speed auto, ARB colour coded summit bar, LED driving lights, duel batteries, BF Goodrich tyres, window tint.
        • Originally posted by azzss View Post
          In the slim chance the egr cooler cracks & has a coolant into intake leak...................
          Not too worried, but it has happened. Worth considering making egr coolers air cooled rather than coolant once flow is reduced
          • Oh ok, thanks for that, I thought it might help cooling by not running through the EGR, (engine runs cooler).
              Sure, it would help the effectiveness of the cooling system.
              • Just bought a 7mm one, im in Sth East Melb, can someone help with some general instruction/direction/link?
                • Originally posted by Khoa View Post
                  After reading the first 10-15 pages, i have an idea of where it should goes ............
                  Reply to my own post - Priceless
                  • So no disadvantage if I was to bypass it? If it helps the cooling system it could only be a good thing!!😊
                    • If you go to
                      http://www.pradopoint.com/showthread...Engines/page10.
                      Ozbush has a link to his “how to install EGR blanking plate”. It's for the 1KD-FTV engine.
                      I haven't done mine yet but the instructions look good, lots of pics.
                      2007 120 D4D GX. Duel Battery, Secondary Fuel Filter, Safari Snorkel, Uniden UH7700NB/AT870 antenna, Scangauge II, King/Bilsteins lift. Rhino rack Pioneer Platform. Maxtraxs and homemade rack side mounts.Awning. And the to-do list is still long.
                      • i wish melb was a quick drive from perth, where are all the 1kd-ftv wizards at in perth?!
                        • Originally posted by MalP View Post
                          If you go to
                          • When I owned an NW Pajero, I installed an SPV Industries EGR controller that could be turned on or off with a switch. It spliced in upstream of the MAF wiring.
                            I then used a scangauge X gauge to monitor the % that the EGR valve was open/closed.
                            Was a brilliant system that could be turned off at service time and threw no codes when in use as it reported certain engine temp values (or similar) to trick the EGR into staying closed.
                            Can someone help to explain why this can be done Mitsu's but not Toyota's?
                            2015 2.8L GX Auto. White. TJM Outback Bar and side steps, IPF 900s, Runva 11XP Winch, Safari Snorkel, Dobinson/Bilsteins, BFG KO2, Uniden UH7700nb with RFI CD34 antenna, Marine Pro 620 Dual Batt with SBI12, Waeco CFX50, Scangauge II, WindCheetah Slimline II Rack...
                            • My egr plate with a 7mm hole arrived yesterday, so today i got stuck into fitting it and pulling the egr to give it a clean.. I pulled the IC piping off and the large metal intake inc throttle body right up to the egr valve.
                              60,000kms on the clock, I was expecting a horror story like some of the posts on here. To my surprise, the egr valve was near on spotless! no hard build up, just some oil and soot! I stuck a long screw driver in with a rag attached and i managed to wipe alot of the shit off.
                              Fitted the plate, bolted everything back together, took it for a test drive and all good! no error codes! I did how ever, find oil in the intake. I read somewhere here that #### was against fitting a catch can? whats the reasoning behind that?
                              anyways it was a productive day, I changed the under body and under bonnet fuel filters, did the air filter and the cabin filter. This coming week my fuel manager pre filter and bracket should arrive, and next will be the oil change and egr coolant bypass.
                              • I don't want to put words in ####'s mouth, but there are two schools of thought to the PCV system. One says to leave it alone, the oil vapours help "wash" the soot throughout the intake system. The other is drop a catch can in to stop the oil vapours to try and prevent the glue that is made. I think from the info that has been gathered if you're running a reduction plate for the EGR the oil vapours will definatly help "wash" the carbon gunk.
                                Personally I am waiting to be able to completely block my EGR system (manual mapper) and run a catch can. The reason this way is the best in my oppinion is the oil film in the intercooler makes it much more inefficient, especially with our front mount intercoolers where the oil will collect in the bottom of it. The only argument against this method is the upper cylinder is not getting lubricated from this oil vapour and it may cause slightly more wear on the valves and valve seats. I guess every thing has a down fall, you've got to choose what you think is best and hope it really is.
                                [LEFT]Silver 150 Facelift
