Wifey arrived home this arvo and told me there was a strong smell of diesel coming from the car. I look underneath and could see a fair amount of fuel residue all over the lower engine components and traced it back to a leak from the front (number 1 ???) injector fuel line where it enters the injector.
This is the front fuel line. It dribbles out while the engine is running at an alarming rate.
I then noticed the number 2 line has a lot of black oily residue around it...
The rear two seem ok.
Toyota are picking the car up tomorrow and will check it out so hopefully it's a quick fix under warranty.
Note: I removed the Chip-It module just in case they knock back the warranty. Does anyone think that the increased pressure in the fuel rail from the Chip-It module could cause this leak or am I just unlucky?
VXWesty
VXWesty
