New Exhaust - Now Heaps Diesel Fumes
  • New Exhaust - Now Heaps Diesel Fumes
    Hi, just had a new 2 3/4" exhaust fitted to my SWB 3 litre diesel and now am getting heaps my diesel fumes from it.
    Now not being mechanical, am thinking there could be at least 2 reasons for this:
    1. extra flow for exhaust and so that is the end result; or
    2. extra flow causing engine to be running rich, and needs a tune.
    If anyone has any suggestions am happy to hear, thanks.
    Vegie
    I assume fumes in the cabin? More likely a leak somewhere. Take it back and take it for a drive with the owner. If he syrvives the gases he can fix it.
      I found the same when I had the Genie exhaust fitted. Had it checked and no leaks, I put it down to the high-flo cat. I wonder if my Genie can answer that question...
        oops double post
          Should have bought the Manta.
            I assume it has a cat?
              Sorry forgot the obvious, no not in the cabin, just in the garage when you start it up.
                An increase in diesel fumes emissions is normal with a high flow cat, even more so with the cat removed. There would also be a bit of a smell from the new exhaust, paint burning/baking, oily/greasy hand marks, WD40 on bolts, etc. Give a a few days and let us know how it is.
                [LEFT]Silver 150 Facelift
                  I too put a High flow cat and straight through muffler on my shorty, running a stienbauer chip too. Also getting an increase in diesel smoke, mostly when you give it a foot full though. Goes like a cut snake! (for a Prado anyway)
                    Yep, I noticed the same when I fitted 2 3/4" Beaudesert.
                    To be honest, when I first bought the Prado, you couldnt smell it was a diesel. Since the exhaust, it now smells like my old hilux surf used to.
