what chip did you have fitted?
Injectors
DP chip. Wasn't advised there could be issues if I chose not to upgrade exhaust straight away either. A big drive combined with towing, big hills and a hot motor and BAM! Have also been advised to have an Exhaust manifold pyrometer installed. Put it down to experience I guess07 D4-d GX Prado, steel cargo racks, 2" lift with poly A/bags in the rear, BFG AT's, Safari snorkel, 2 way, diff breathers, electronic rust protection, Donaldson back up fuel filter, 6 x IPF spotties, ARB c/coded Delux B/bar and under body protection, Black widow draw system with c/barriers, dual batts with Engel 80ltr fridge/freezer and plenty more on the 'To Do' list!
Originally posted by Anth120playdo View PostI will be sticking with my time bomb :-)Dave
Originally posted by Mick70 View PostDP chip. Wasn't advised there could be issues if I chose not to upgrade exhaust straight away either. A big drive combined with towing, big hills and a hot motor and BAM! Have also been advised to have an Exhaust manifold pyrometer installed. Put it down to experience I guess
Originally posted by Anth120playdo View PostLikely.
Maybe not.
Get it plugged Into a scan tool ASAP.
To give you guys a bit of history, the car has always had synthetic oil put in it from new, however the last service (about 5000ks ago) they put in normal mineral oil.
Toyota checked injectors and ran some tests and found everything to be ok.
They flushed out the mineral oil and filled it up with synthetic and the rattle is less noticeable.
They flushed out the mineral oil and filled it up with synthetic and the rattle is less noticeable.Cheers
Micheal.
From wat you say id be thinking to check the oil pressure.
Just thought I read that somewhere on their site when I wax thinking about getting one.2011 Crystal VX 150 | ARB Deluxe Combo Bar | Safari Snorkel | IPF 901XS Driving Lights | Cooper A/T3 265/60R18 | Hayman Reese H/D Tow Bar | GME TX3540+AE4702 UHF | Warn XP9500 Winch.
Does anyone have a reputable suggestion where in Sydney I can get the injectors tested/checked? Preferably on the Northern Beaches (or Botany area).
ThanksLast edited by cbm8880; 05-06-2015, 10:45 AM.2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
2008 Jayco Dove Outback - "Davo"
Give Baileys Diesel Group a call.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Have a look at the web site for Bailey Diesel Group - they seem to be the Australian guru's on all things diesel - CRD in particular. They do after market injectors rebuilt and blue printed. There is a lot of good info on their site, which I have found very helpful in understanding Prado fuel systems.
