Scangauge II X Gauge Codes for 6 Speed Auto 1GD Prado
    How did you go Cuda,
    Find anything else while talking to toyota
    Arb colour code deluxe bar, safari snorkel, lightforce venom HID's, GME uhf remote face, redarc tow pro, redarc bcdc 1240, pioneer platform, 40" curved light bar, dual battery, 3" SS exhaust, EGR mod, trans cooler upgrade, provent catch can, scangauge 2, diesel care secondary fuel filter, Tin's bash plates and actuator gaurd, 2in Bilstien and kings lift,
      I am considering the purchase of a scangauge II and just wanted to check with those that have them - do you rate them? Worth the money? It looks pretty good and a bit of security for the new dpf prado's..
      2016 Toyota Prado GXL auto. ARB deluxe bar, Rock Armor side steps, 9in Penetrator LED spotties (30,000LM), Uniden 8060 UHF, Bilstein/Dobinson 2in lift, 265/70/17 Mickey Thompson ATZ P3's, Safari snorkel, Dual battery system, ARB onboard compressor, Custom rear false floor, Kaon bash plates, Ext. diff/gearbox breathers, Provent 200, Wynnum tow bar, Roadsafe tow points, Phillips crystalvision bulbs, tint, Rhino rack platform.
        I rate mine 100% cheap insurance to keep eye on trans temp, water temp, egt , boost, volts i could go one more.
        Plus being able to pull out codes and clear if something happens while remote.
        There are other brands out that i cant comment on but scan is great for me.
          just wondering if someone has the codes for monitoring boost ? ive added the 4 listed above to mine and they work well. the car is doing a DPF burn every 200k on a long cruise , dont know whether that is good or bad
            Yeah i got boost cant remember how think it was a std sensor on the scan gauge
              All good the last code you provided worked. Thanks.
              Had the car in for service and complained about the transmission yet again. They check fluid levels and said 5ml top up. Looked at my Canbus as there were some issues with the dash going out and warning lights coming on. Interestingly after the work they did my transmission is far smoother through the changes now.
              I drove a 10,000km Hilux and yes they definitely have more pickup I guess due to the lesser 400kg but the 5th and 6th gear issue was present. So it must be across all 6spds and will only be resolved with a transmission firmware update.
              Regards
              Doug
