Scangauge II X Gauge Codes for 6 Speed Auto 1GD Prado
  • Scangauge II X Gauge Codes for 6 Speed Auto 1GD Prado
    Hi guys,
    I'm not sure where to put this info.. Sorry if its in the wrong spot or if it has already been covered.
    After a bit of experimentation with around 10 different X-Gauge codes from the Scangauge site, I am pretty sure that the following code works for ATF Temperature in the new 6 speed auto 1GD Prado:
    ATF Temperature 4
    07E02182
    046105820000
    2808
    00010001FFD8
    For 2011+ AUSTRALIAN FJ Cruiser. May work on other Toyota vehicles 2010+ if the other gauges above have not.
    Hope it helps someone. Please let me know if you have information to the contrary.
    Mike.
    2015 2.8L GX Auto. White. TJM Outback Bar and side steps, IPF 900s, Runva 11XP Winch, Safari Snorkel, Dobinson/Bilsteins, BFG KO2, Uniden UH7700nb with RFI CD34 antenna, Marine Pro 620 Dual Batt with SBI12, Waeco CFX50, Scangauge II, WindCheetah Slimline II Rack...
    Originally posted by Mild7 View Post
    Hi guys,
    ATF Temperature 4
    07E02182
    046105820000
    2808
    00010001FFD8
    Mike.
    Thanks Mike, very helpful indeed.
      Awesome been tring to find that.
      Also I found the torque convertor one it's
      07e02182
      046105820000
      3808
      00010001ffd8
      Hope helps to
        Found exhaust gas temp between the turbo outlet and the DPF uased a combo of numbers to get haven't checked with temp gun as yet to see if gauge is acurite.
        Txd o7dfo178
        Rxf 054106780000
        Rxd 3810
        Mth 0001000affd8
          Nice one Hally.. If it works. What sort of numbers are you getting?
            Hi-way driving showing 340 degres c avg
              Thanks mate. Will be trying this tonight 8-)
                EGT seems to work perfectly well thanks Hally.
                Last weeks trip from Melbourne to Merrimbula had me around 380-400 at 100-110 kph on the flat. This was fully loaded inside and on top with 265/70/17's. Went to a maximum of 505 degrees C for a few seconds coming up the hill to Gumbaya park, but not past 480 for any other part of the trip no matter the slope.
                Thanks again.
                  No probs
                  I also found the dpf one not sure if inlet or outlet of dpf. Will post it up when i get a chance. Temps get around 6-700 for it when doing a burn.
                    Originally posted by Hally View Post
                    No probs
                    Did you end up finding the codes for the DPF sensors?
                    Doug
                      Not definitely, have got something but not exactly sure what it is.
                      Ill try to Remember and post what its is later
                          Im 90% sure this is Dpf this arvo car was doing a burn and egt was 340 and dpf was 520.
                          TXD 07DF0178
                          RXF 032100000000
                          RXD 2010
                          MTH 0001000AFFD8
                          Let me know how it goes for you
                          Hally
                            Im 90% sure this is Dpf this arvo car alwas doing a burn and egt was 340 and dpf was 520.
                            TXD 07DF0178
                            RXF 05410678000
                            RXD 4808
                            MTH 0001000AFFD8
                            I tried these values but no joy. No data being displayed.
                              Not sure what happened but wrote the wrong ones down.
                              I have edited the above one to correct (i hope)
                              Hally
